so i just blew a second headgasket tonight. im tired of this, what did i do wrong? (besides turbo e30)
i used a goteze headgasket, meteric blues, and i looked over the head, it seemed true and not warped. i torqued them to 30ftlbs wait 5 min, 40, 50, and then 60.
i have 42lb injectors and @ 1bar of boost, the temp needle was alittle below vertical. i tuned it myself and i had it so that under boost a/f was right around high 12s verry low 13s. i have ngk BPR7ES plugs gaped to .023
its blowing under the intake plenum closest to the firewall in the middle of the last cylinder, is there something i overlooked or is this just going to keep happening?
