boost from boot to boot
  • iXe<30
    • 143
    I might replace some of the return with two of those really thin intercoolers. Also i am not lowering the car significantly. Im one of the few who love the stance of the e30. would two small intercoolers one after the other reduce flow? i know im crazy guys... Unless i can fit a normal one back there easily...(with the wheel hump gone) Which i Think it will.
    • einstein57
      • Jun 2007
      • 10780
      I sugguest reading a couple turbo books before you buy anything or come up with any ideas.
      www.gecoils.com
      • iXe<30
        • 143
        eah this is a feeler... im soakin up as much info as possible. My biggest concern is tuning.... i feel like i have to go megasquirt eventually. i Intend to start at low boost though so i could maybe do war even so im concerned about the maf being in the boot..... that shouldnt be to bad...
        • custom e30
          • Nov 2009
          • 347
          do it, i love the idea of the rear turbo mount, but u gotta figure out how to do ur oil in and out lines, "oil in" will be easy but the exiting part will be tricky
          • iXe<30
            • 143
            already looked into it and have a heat resistance electric pump picked out ;)
            http://www.ebay.com/itm/TurboWerx-Ba...sories&vxp=mtr
            I thought about this but figured why risk it..
            http://www.ebay.com/itm/NEW-Rear-Mou...sories&vxp=mtr
            • einstein57
              • Jun 2007
              • 10780
              Don't buy temporary parts. Get what you want from the start and you'll save lots of time and money.
              www.gecoils.com
              • iXe<30
                • 143
                thanks thats what i meant by "why risk it". thanks for the positive help man. MUCH appreciated.
                • BergerNJ
                  • Oct 2009
                  • 349
                  theres a reason why remote mount turbos exist...sts makes good money proving why they are good and work great
                  some of the v8 guys like the tt vettes use remote mounts simply to distribute more weight and nothing else....maybe also to avoid the extreme heat. You will also notice the remote systems seem to be swayed towards twin set ups to achieve faster spool and desired boost with smaller turbos...
                  trucks use the tt systems a lot too......remote mounted systems are pretty bad ass in my opinion and anyone running one properly gets a thumbs up in my book
                  check that out.
                  STS and a lot of custom guys have posted proof all over the internet that lag and the difficulty in reaching desired boost is a myth, you just need to do it right. My biggest worry would be the oiling system, getting boost is easy with the right piping and a properly sized setup
                  plus you can hear the turbos spool in the exhaust much easier, sounds better imo
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    In theory it sounds fun and different but you are much better off doing a bottom/top mount in the engine bay.
                    I am sure with enough R&D/time/money it could be done but at the end of the day, i will make the same power while spending less money.
                    Good luck on whatever you decide.
                    Project log -- DIRTY 30
                    2.7i * Megasquirt tuned * E85 powered
