Not feeling the BOOST!
  • BMWZ318is
    • Nov 2008
    • 102
    #31
    IMG117 by ZacE30, on Flickr
    IMG118 by ZacE30, on Flickr
    IMG119 by ZacE30, on Flickr
    • BMWZ318is
      • Nov 2008
      • 102
      #32
      if there are certain things you want me to take a pick of just let me know
      • BMWZ318is
        • Nov 2008
        • 102
        #33
        one thing that is also different from the last time i had it running is im using the stock exhaust manifold gasket before i was using the one they sent with the turbo mani
        • Mr. Burns
          • Aug 2011
          • 3516
          #34
          well now...thats a nice and clean setup for sure.
          I would start simple in that case...
          open BOV/wastegate?
          vac leaks?
          nothing obvious jumps out to me...
          Originally posted by flyboyx
          i have watched my dog lick himself off a few times
          • ak-
            • 12422
            #35
            I skimmed over the thread and just read this;
            Originally posted by BMWZ318is
            My boost gauge doesnt show boost but it will show vacuum. all the pipes are connected nice and tight. and one of my friends suggested that i change it to see if it would read differently.
            This, leads to this:
            its a t3/t4 .60 a/r its an ebay turbo
            I'm willing to bet your turbo is blown.
            Ebay turbo's are hit and miss. Took a friend 2 weeks to blow his, and another 1 year.
            There is also a thread on here with some dude in a bronzit running one for 2 years lol.
            1991 325iS turbo
            • jaywood
              • Jul 2010
              • 4528
              #36
              I have eBay turbo. The guy before me used it for a year, and I almost have a year on it now. So that's about 2 years, and I have a bronzit. I know they guy you're thinking of though ^^^
              Good luck finding the problem!
              • kamotors
                • Nov 2007
                • 7102
                #37
                setup is a lot cleaner and simpler than I had envisioned. only thing I can think of is a dead turbo, BOV constantly leaking air, wastegate open. If your boost gauge is showing vacuum its all good its just the fact that your simply not making boost.
                is the gauge getting close to zero under load?
                7speedshop.com
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  #38
                  running ebay turbo here too.
                  .60AR CX Racing whatever the generic chinabrand is...
                  over 1 year no issues...
                  but I wouldn't rule out blown turbo.
                  certainly you would not of installed it with a grinding wheel etc
                  • blueapplesoda
                    • Dec 2005
                    • 1904
                    #39
                    Wastegate stuck open? Do you have its vacuum lines plumbed correctly? Have you got a new boost gauge? they sell them at pepboys...just grab one and return it when you are done.
                    The turbo is such a simple device I don't know how it could be bad...but don't rule it out
                    • BMWZ318is
                      • Nov 2008
                      • 102
                      #40
                      i tested the wastgate and its functioning properly and yes the gauge will go up to zero but wont go past zero thats under a load while im driving. If the turbo is spooling and the BOV is releasing pressure when i let off the throttle could the turbo still be blown. im running an i head on an e block could that be an issue?
                      • einstein57
                        • Jun 2007
                        • 10780
                        #41
                        Those T3 gaskets suck. I've blown them out in a week. Would be hard to hear the leak with an open down pipe.
                        www.gecoils.com
                        • BMWZ318is
                          • Nov 2008
                          • 102
                          #42
                          thats true and ive reused my turbo gasket like 3 times ha ha
                          • TS87325IS
                            • Sep 2006
                            • 821
                            #43
                            Sounds like an exhaust leak inbetween the head and the turbo or the waste gate is stuck open, or an intake leak on a charge pipe. Thats the only things that come to mind. Its a head scratcher for sure :-)
                            mods: just meat and potatoes under the hood and wheaties on fire out back ;)
                            • BMWZ318is
                              • Nov 2008
                              • 102
                              #44
                              could it be a mix that my boost gauge doesnt work and im making boost but im not feeling it hit boost cause my tune sucks
                              • Kvasi
                                • Apr 2011
                                • 1122
                                #45
                                You should get a wideband before you go on.
