M10 turbo questions
    M10 turbo questions
    i have decided that i want to turbo my engine in the near future, but as im sure you have all suspected, i have no money! so i was wondering if a turbo could be done for 800 dollars, the bare bare bare minim i can get away with. im only looking to run around 8 psi, at the start as time goes on i will build it up. so anyone is this doable and in any way realistic?? also is there any good diagrams of turbo set ups or good books that i can get my hands to to learn all i can? thanks for your thoughts
    How long realistically do you want/expect the motor to run?
    ADAMS Autosport
      No.
      It's really that simple. The answer is no.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
        well forever of course! honestly i would like it to be fairly reliable im talking to hvturbo and he has a manifold i could afford that bolts to a t3 turbo and his system dose not use an inter cooler so i really like it, makes feel like this is doable.
          DO NOT run an intercooler-less turbo system. Common sense. You WILL need an engine management system (Figure $200 minimum for MS if you can find a deal on it). A manifold or adapter (you could make an adapter for around $50 or so). The turbo you can find for Free-$300. Then comes the intercooler/blow-off-valve/wastegate. In reality, yes, you can turbocharge your vehicle for the cost of a manifold/adapter and a turbo. But, it will run like shit, and blow your engine without the rest of the system. Do more homework, figure out what you need, and don't rush it, or you will regret it. The m10 is perfectly slow the way it is. Until you are ready to throw some real money at it, leave it the way it is, and it will treat you well
          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
            im not sure were to start, i get what your saying and ya it makes sense and i want to make sure it is reliable. honestly i was thinking about getting a top end off another 318 and replacing what i need to upgrading what i need to ( rockers and head bolts) and cleaning it all up new gaskets when i up it on all that good stuff. i only have one car and i live on my own so this way my car wont be down.
              8 lbs is fine without an intercooler. IF you do your research and can fabricate, $800 isn't that unreasonable.
              1997 540i/6 - stock
              1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
              1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                one thing why do i have to run with an intercooler at such low boost? i know it wont be as efficient but will it be that big of a problem ?
                  you don't.
                  1997 540i/6 - stock
                    It's common sense though. An intercooler will lower intake temperatures which will help with detonation which in turn will help your engine last longer since you haven't mentioned anything about management. Do you have a way to retard timing under boost?
                      no i dont i was going to do a little while after MS after is there nothing i could to do bring downthe engine temp at all other then an intercooler?
                        Yeah, do what HSV did and run TONS of methanol. Also, how do you plan on adding extra fuel under boost?
                          how dose methanol keep the engine cooler? and ya i was thinking about that i dont think a rising rate fuel regulator will quite do the trick lol
                            The RRFPR will work for the fueling, but not for the ignition. Methanol burns at a MUCH cooler temperature. If you are looking at a RRFPR, pretty much only look at a BEGI unit. You can retard your timing by turning your distributor counter-clockwise a little, but with the RRFPR you will have to choose between good running out of boost OR while on boost. That is the common complaint, can't get both with that sort of management.
                              for argument sack let say i just run like 91 gas, would that help with the rrfpr smoothness?
                              opps i said sack instead of sake my bad.
