FILM: E21 Extreme S54 Turbo 1000whp on trackday..
  • oddis
    • Jan 2009
    • 53
    A mate of mine buildt a E21 from scratch and bolted in 1000whp S54B32 turbo engine.
    Then he took it for a spin at the track... and here is the result :) The clip contains both driving and build pics. It will cover at least a couple of days need for your weekly BMW Turbo fix.
    FILM 2012
    Edit 2013: A year has soon gone by, and the build went big and become a "grand slam" winning ****loads of trophies.
    I put together at little video:
    FILM 2013: BMW E21 TURBO - Winning it all
    Speedhunters feature: http://www.speedhunters.com/2012/07/...street-sweepe/
    BMW 1000HP Turbo Videos
  • 5Toes
    • 9836
    WOW. I am surprised he attained that power on only 2bar boost
    • ak-
      • 12422
      yeah, 29lbs of boost does stuff to engines
      1991 325iS turbo
      • sayed ali
        • 762
        Wooow! 2bar = 1000whp :):)
        M20B28 Turbo
        My Build Thread
        http://www.r3vlimited.com/board/showthread.php?t=255839
        • e30shmobberr
          • 1934
          dont forget E85! thats a factor right there too.
          but holy shit this thing is wicked! bet spency will cream over this
          Patrick - IG:niicknac
          RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
          • JCarp90
            • Feb 2011
            • 1759
              • 34844
              why?
              stock S54 makes 333bhp on 1 atmosphere of intake pressure, so it makes pretty good sense that it can do 1000+ on 3 atmospheres of pressure + supporting mods.
              • oddis
                • Jan 2009
                • 53
                The S54 beeing the most efficient and optimized inline 6 production engine in the world it's not hard to understad the enormous power increase at boost.
                Oldtimers say 1.0 bar = 107% increase in hp if stock compression/headsetup.
                Compression is taken down for more potensial at higher boost, more accurate engine management system and better fuel E85 than stock. Just getting rid of the air mass meter is a big issue.
                Another big issue, however not on the hp front is the VANOS block off. With VANOS enabled it would easily could have had a more brutal tourque and power delivery. 1200Nm @ 4500rpm and a 100% increase in torque in middle range Andreas at PPF claims. But still with well over 1100hp at the flywheel there will probably be no problem with 1100kg car.
                But then we probably talking engine block cracking time very soon.
                With even bigger turbos it would be no problem to break 1500hp, as the S50B32 euro does 1400 very well already.
                • FredK
                  • 14763
                  That is insane amounts of power! The acceleration looks so violent!
                  • oddis
                    • Jan 2009
                    • 53
                    New upgrades this season is active vanos, topmount turbo and som other small details :) The driveability will increase drastic. And alot more torque low down due to vanos.
                    • BMWManiac
                      • Dec 2010
                      • 1091
                      You all do amazing things to BMWs there in the Netherlands....
                      1997 Artic Silver M3
                      CES GT4094r 651hp/615tq @ 24 psi
                      • oddis
                        • Jan 2009
                        • 53
                        We are from Norway.. ;)
                        • 325ix
                          • Aug 2009
                          • 7783
                          You Norwegian types love your turbos.
                          • sayed ali
                            • 762
                            e30 looks SICK! :)
                            M20B28 Turbo
                            My Build Thread
                            • IronFreak
                              • Dec 2012
                              • 3702
                              This is epic......screw it, I moving! There is obviously something in the water over there that makes magnificent turbo builds possible.
                              Instagram @rebellionforge
