What rods?
  • 86325LSD
    • Aug 2004
    • 296
    What rods?
    Eagle, K1, or Molnar ....easy question right. Which one has best finishing and QC?
    I am aware that they are all likely the exact same part to start, but who do you think does the best finishing work to get a good clean set of 6 with round ends and good dimensions?
    **update** I bought Eagle rods see below for m,y initial QC of them.
    9
    Eagle H beam
    88.89%
    8
    Molnar H beam
    0.00%
    0
    K1 H beam
    11.11%
    1
    faint in, throttle out.
  • classified
    • 61
    What engine are you looking for rods for? Budget?
    • LowR3V'in
      • 4209
      He's asking what the best brand is.
      • JCarp90
        • Feb 2011
        • 1759
        Eagle because I'm a fanboy.
        • downforce22
          • Aug 2009
          • 3192
          I have a set of H beam and with my stroker setup the rods didn't clear the block. Had to make a few adjustments. It was less than a mm though. Thats with a 89.6mm crank though.
          • erinender987
            • Oct 2012
            • 1
            rod cells are to intensity of light as con cells are to colour.
            generic printer ink cartridges
            • euro2fast4u
              • 545
              what engine management are you using for your turboed car?
              • SkiFree
                • Jun 2011
                • 2766
                Add Ireland Engineering H-beams and VAC's "SP components" to that "same part" list.
                A good method of QC in general is balanced to within a gram or two, ARP2000 rod bolts put in, and tolerances checked out. Since I work at IE I know this is what happens, and should happen elsewhere if your getting them from a half decent source (i.e. someone who cares._.
                ADAMS Autosport
                • 86325LSD
                  • Aug 2004
                  • 296
                  WENT WITH EAGLES FROM HERE based upon price.
                  Here are my thoughts on initial observations:
                  They arrived in just 1 day with the free shipping!!
                  The rods came as described. All dimensions calipered out appropriately for the stock m52 series motors ( works for m50nv and s50 as well - L135mm/BD48mm/PD22mm ).
                  The rods weighed in a range from 547.408g to 548.288g. That was well within the 2 gram promised window (+/-1g).
                  The rod bolts included were all 12 point ARP 2000's and it included the lubricant and instillation instructions, plus STICKERS!!. Surface finish could be better (its not polished) but for a $465 H-beam rod set the initial quality exceeded my expectations.
                  A+ for the money thus far. I will update review again on performance after instillation and dyno testing.
                  gK.
                  PS: its nonvanos so megaqsquirt 3
                  • sirajuljony
                    • Mar 2013
                    • 1
                    Rod cells are more sensitive than con cells. It is always responsible for night vision.
                    low cost generic copier ink
                    • ak-
                      • 12422
                      Take it from a professional.
                      Because night vision.
                      1991 325iS turbo
                      • digger
                        • Nov 2005
                        • 6140
                        Who makes light weight and compact (to clear the bottom of cylinder) 135mm aftermarket I-Beam rods?
