e30 s50 turbo what rear end to use ?
  • bmwdready347
    • Jan 2011
    • 586
    hi have a s50 turbo e30 and im going to dyno soon ,i should be makeing 450 to 500 whp and wanted to no what rear end to use ..
  • ak-
    • 12422
    260 or ZF transmission?
    1991 325iS turbo
    • Robotin
      • Jun 2011
      • 4471
      from what ive heard from people in the past. using a S3.25 out of a e36 m3, or a S2.93 out of a ES e30 (or optioned eta).
      1989 325i SETA stroker [delphin] R3V'd 8/31/2011
      1989 325ix [zinnoberrot] $OLD
      1970 2002 [Nevada]
      Originally posted by Herr Faust Schinken
      guy must have slid into something that doesn't look like a car vs car hit
      Originally posted by ak-
      Must of slid into Rob
      • bmwdready347
        • Jan 2011
        • 586
        im useing the m3 zf tranny and thanks for the reply..
        • ak-
          • 12422
          It's important to know what transmission he's pairing it with though.
          An s2.93 on a ZF is like an s3.25 on a 260trans, sort of.
          But an s2.93 on a 260trans is balls.
          1991 325iS turbo
          • ak-
            • 12422
            You want an S2.93 then. I can't imagine using anything higher to have a usable 2nd or 3rd gear.
            My bud is going through the same process right now, s52 turbo e30.
            1991 325iS turbo
            • Cyrix2k
              • 593
              2.93 or 2.79
              1997 540i/6 - stock
              1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
              1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
              • bmwdready347
                • Jan 2011
                • 586
                Thanks I have a 293 and will put it on this week
                • Robotin
                  • Jun 2011
                  • 4471
                  go big, 373 or 411
                  1970 2002 [Nevada]
                  • Lurker27
                    • 821
                    m30 turbo (~500rwhp ~600rwtq) has no traction in 3rd already with a 2.93, it's tall but going higher is literally retarded
                    '89 335is +turbo
                    • rneedham1979
                      • Jul 2008
                      • 852
                      I run a 2.93. I have run as low as 3.46 but it wouldn't fully load the turbo in 2nd. The car would go through the gears too quick. The 2.93 is leaps and bounds faster... I get full boost in 2nd and she just pulls for ever. Less shifting too
                      Turbo E30
                      Roadkill 80lb 93 octane OBDI tune
                      BavSol Cylinder Head
                      Stock S50 in. cam Schrick ex. cam
                      Otis' tubular T4 manifold
                      Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
                      GT4094r w/Batmowheel Impeller
                      614whp@17.5psi, 100 Oct
                      690whp@21psi, 100 Oct
                      801whp@27psi, 110 URT
                      Old: 1/4 mile: 10.91@144.38 (636whp)
                      New: ?
                      http://www.youtube.com/watch?v=L_f7fUVqblI
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5275
                        Turbo? S2.93 definitely
                        Originally posted by priapism
                        Originally posted by shameson
                        • SwiftE30
                          • Jun 2010
                          • 998
                          ^this. picked up one at the end of summer. can't wait to see how it feels with my turbo.
                          1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                          • einstein57
                            • Jun 2007
                            • 10780
                            Impressive. From what i hear that pretty hard to do with that motor.
                            www.gecoils.com
                            • Lurker27
                              • 821
                              The pistons are thermally limited, I run meth+water inject on the biggest mcmaster nozzle. I also have a ported custom cam, flipped manifold, oring'd block w/ ARPs, bottom end rebuild, full 4" exh. It blew up my trans though so it's down right now.
                              would not recommend more than 15psi on a stock motor, they just choke past that anyway, M30s are terribly lift limited, so you need a very on point valvejob and then a cam can run 30% more valve curtain or so and wake it up @ high rpms
                              '89 335is +turbo
