Help please on M20 turbo build, starting from scratch
  • Chuckcruzin1986
    • Jul 2009
    • 130
    I have read and read but I am having a problem putting the puzzle together, so I have made a list of questions. Please help.
    Car: 1986 325es
    Engine: 2.7, balanced with Super eta pistons (notched a little more), 885 head, milled .05", thermal coated valves.
    I have Megasquirt and 3 coil gm wasted spark already.
    Questions:
    Exhaust Manifold? Adaptor mounted to the original iron units or full tubing? Brand?
    I do not understand split pulse.
    Turbo brand and size? I am leaning more towards driveablility (This is not a track car).
    Intercooler or ethanol, water injection?
    Head bolts are stock. Must I change them and how about the head gasket?
    Injector size?
    Fuel pump?
    Exhaust: I do not want a loud car. Resonator and original muffler?
    Engine has adjustable cam gear: A good place to start?
    Thoughts that I have not hit on would be appriciated.
    Thanks for any help provided
    Chuck
  • sayed ali
    • 762
    FIRST: decide your power goals?
    then you'll know weather you need a head studs or not, what size injectors, what turbo, etc...
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • einstein57
      • Jun 2007
      • 10780
      Start HERE
      Then read a few build threads HERE
      Should cover most if not all of your questions and save you money.
      www.gecoils.com
      • deutschman
        • May 2008
        • 5958
        By those questions it seams you have done no reading. Sorry
        Get Maximum Boost: Designing, Testing, and Installing Turbocharger Systems by Corky Bell
        http://www.amazon.com/Maximum-Boost-...++++Corky+Bell
        • Dj Buttchug
          • Jun 2010
          • 7680
          swap in m50
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • Hey_You
            • Nov 2009
            • 963
            Many people run a HOLSET hx35, there is a good reason why. It is a divided entry turbo, but a split pulse manifold is not needed as a simple t3 flange will work. Injectors from what I hear is a good idea for cc's to match how much power you want (ie, 440cc injectors for 400hp). Run a stock head gasket with ARP studs, it's a proven combination. Run a front mount intercooler and upgrade your fuel pump to a wahlbro unit as to not strain it. Exhaust you can figure out on your own. Now do some research and you will find your questions have ALL been answered time and time and time again.
            85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
            • Chuckcruzin1986
              • Jul 2009
              • 130
              Studying......... reading.... knowledge
              I try hard not to bias someone when I ask a question.
              Example: I like green, what color should I paint my car?
              I try to ask questions to see what people can contribute, not to show what I know. So, it may make me look dumb :yawn:
              Thanks,
              Chuck
              • kamotors
                • Nov 2007
                • 7102
                Exhaust Manifold? Adaptor mounted to the original iron units or full tubing? Brand? doesn't matter both will get you boosted reliably
                Use a brand name turbo, preferably NEW not used if reliability is a concern. .63-.68A/R will produce a real quick spool
                intercooler+ water injection keeps things safe
                stock gasket and bolts are good to around 12psi anything more and you should do ARP head studs and a fresh OEM gasket.
                Injector size?
                60lbers
                Fuel pump?
                New stock works fine on my car all the way to 23psi
                turbos quiets things down quite a bit, stock sized muffler will keep things quiet.
                not really needed
                Chuck
                7speedshop.com
                • Chuckcruzin1986
                  • Jul 2009
                  • 130
                  Good thoughts
                  Thanks for the help. I bought 2 books and am reading now. Also thanks for the specific recommendations. Spring will be in the air soon (I am a dreamer) and hope to have the installation finished after the salt has been washed from the steets by a nice fresh rain.
                  Chuck
                  • Chuckcruzin1986
                    • Jul 2009
                    • 130
                    Reading up on Turbos?
                    Thanks for the tip on the book.......... it really is the only way to go. There are many details that I have learned.
                    Thanks,
                    Chuck
                    • deutschman
                      • May 2008
                      • 5958
                      Hey Chuck. I did not mean to be rude. My bad if it came across like I was.
                      Hope that book helps out. When you get to actually building the turbo system, I'd love to read a build thread and see how you tackle the build.
                      Cheers
                      J
                      • einstein57
                        • Jun 2007
                        • 10780
                        I get no credit?
                        www.gecoils.com
                        • Chuckcruzin1986
                          • Jul 2009
                          • 130
                          So Sorry
                          Originally posted by einstein57
                          I get no credit?
                          Great books and thanks :)
                          Chuck
