ebay turbo manifold twin scroll modifaction
  • e30m20TurbO7
    • 1203
    does anyone think its possible to convert this to twin scroll
  • sayed ali
    • 762
    I can vote for the good quality, but about the price there are some adapters like
    http://www.ebay.com/itm/87-91-E30-BM...34dc0e&vxp=mtr
    Or you can do a homemade adapter will be alot cheaper.. all depends on your goals ..
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • e30m20TurbO7
      • 1203
      thanks , how much did you're twin scroll run you
      • Rc 415
        • Jun 2011
        • 723
        The manifold linked in the first post is actually an eBay manifold being sold and marked up by max-redline
        1987 Delphin 325IS
        LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
        Build Thread
        1993 alpine 2 325IC
        •Ground control coilovers•16" BBS RS• momo woodgrain
        • ak-
          • 12422
          No because all the branches collect into a cube with the turbo/turbine sitting on top of it. I mean, sure you could technically divide it, but after the labor and cost of doing so you probably would want to go with something else off the shelf.
          True!
          1991 325iS turbo
          • Pootis
            • 636
            This manifold adapter is not a direct fit I had to have mine modified to actually bolt up but if you know how to weld or have a good exhaust guy its still a good deal
            1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
            COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
            • Cronopoulos
              • Jul 2011
              • 2187
              My guess is the turbo you bought is twin scroll?
              Project log -- DIRTY 30
              2.7i * Megasquirt tuned * E85 powered
              • FLG
                • Sep 2011
                • 3165
                666 fab makes a twin scroll, but be prepared to spend over 1k on a manifold.
                The ebay one works for the cost, though they all eventually crack. Right now mine is holding up, supporting a hx35 (twin scroll turbo) and in 5th she spools at 3k (which is fine with my 3.73 gearing which keeps it right in the power band)
                You could get a quick spool valve which ive heard works well. Will cost you a bit (think they go for like 400-500$) but from my reading they do help spooling.
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • downforce22
                  • Aug 2009
                  • 3192
                  I was thining about making a quick spool valve for my undivided manifold and divided turbine housing.
                  • FLG
                    • Sep 2011
                    • 3165
                    Idk probably a ton of r&d work that goes into it. It is fairly simple but with exhaust temps as high as they are youll need to make sure you design something that dosnt get hung up or leak.
                    These seem to be the ones to get
                    PLEASE NOTE THESE ARE CURRENTLY ON BACKORDER UNTIL SOUND PERFORMANCE HAS A REPLACEMENT ACTUATOR OPTION. WE DO NOT HAVE A TIMEFRAME OF WHEN THESE WILL BE AVAILABLE AND READY TO SHIP AGAIN ALL VALVES ARE NOW THE HD VERSION!!! Okay, so you have read or are about to read what is below and you want the brief-no-nonsense quick opinion from SupraStore. Here it goes. The greatest single complaint we get from people switching from stock twins to a larger single turbo is LAG. Many people are just tired of having to deal with the lag of a bigger turbo. Bottom line, with the quick spool valve, your 62-67mm single turbo will spool quicker, hit harder and faster, and make much better torque and horsepower than your stock twins! End-of-story, read the stuff below for the technical nuts-and-bolts. What about bigger turbos? Same result: spool quickly, lag minimized, bam!! Now that you are convinced, watch the video and notice the first two dyno runs without the quick spool valve in quick spool mode, you will see how long it takes after the driver put the accelerator to the floor for it to get on big boost and spool. Now, fast forward to around 1:42 in the video and watch the quick spool switched on. Pay attention or you will miss it, as soon as the driver nails the throttle, WHAM, BAM, it spools NOW!! Oh - why buy from us? Simple, I have personally known Larry at SP for years, have tormented him back in the day and was running 900rwhp+ 10 years ago on a stock motor with one of the first SP74mm turbo's on the planet. That isn't a reason? Well, then, we sell it for LESS!! Are you a hard core racer, running explosive anti-lag or 2-step blasts on your car? If so, worry not, as all of the QSVs are now the HD version for us hardcore enthusiasts! This is one of the BEST upgrades for everyone running a T3 T4 or T6 turbo. The Quick Spool Valve has proven to produce as much as 150ft/lbs MORE TORQUE in the midrange of the powerband, AND it will make more peak power as well due to the turbo spooling faster. The Quick Spool Valve has a butterfly valve blocking a scroll of the divided turbo housing, making the turbo act as if it were a smaller turbo. All the exhaust energy is routed through half the turbine housing, causing the turbo to spool at a much more rapid rate. In other words, the spool valve is essentially "halving" the turbine A/R when the valve is closed, and then you get close to full A/R when it is opened. For example lets say you have a .86 A/R 76GTS turbo. With the quick spool valve operating, at lower rpm's it acts like a turbo with a .43 A/R housing, which means it spools very quickly, shifting the power band downward on the curve and allowing for much quicker build up of hp and torque! When the valve opens, you end up with about 95%+ of your total A/R available and full boost. Incredible for street cars!!! The switching solenoid can be wired up to open at a set point and when the valve opens up, you have the full potential of your turbo with no sacrifice of peak power. The Quick Spool Valve thickness is 3/4" so this is going to require either modification to the exhaust manifold or the downpipe to compensate for the height increase of 3/4". The valve sits between your turbo exhaust housing flange (sometimes called a footprint) and the exhaust manifold. All QSV's require final fitment by the installer and may require slight clearance mods depending upon the turbo. People are asking, "how does it work with smaller T4 turbos? " Well, it works fantastic, as the design is not dependent of a large turbo, or for that matter, a large A/R. A 7MGTE owner with a 62mm turbo (see dyno sheet) was able on stock 7MGTE with SAFC on stock ECU to see a shift of 500-600rpm sooner spool, and a maximum gain of 50hp and 71torque at 3500 rpm! The red line on the dyno sheet is a dyno run with the valve closed; the blue line is with the valve open, as if there was no valve. YOU MUST HAVE A NON DIVIDED MANIFOLD! If you have a divided manifold, we offer our own QuickSilver manifolds to suit your needs. Note: International shipping includes most of the UK & Australia. Other major cities may be the same or more depending upon location. If your city costs more for shipping charges we will notify you of the price before we charge your credit card.
                    • downforce22
                      • Aug 2009
                      • 3192
                      All it is is a wastegate actuator on a rod built into a metal spacer. The hardest part would be choosing a bearing for the heat in the exhaust. Something I still need to think about/ look into if I ever do it. It is retarded that it costs so much
                      Here is a home-made one.
                      • LowR3V'in
                        • 4209
                        Revshift used to make a stainless adaptor
                        for alittle more then that pile of garbage manifold. :(
