Turbo Fuel Question
1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
Originally posted by Pootis View Post1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
1984 316 Coupe - The Base Model - Pain in the Ass
1988 750iL - The Daily Driver
...And a couple others...
HX50 will work well around 18psi and up. I tried the HX55 on my B34 M30 with a twinscroll manifold and it spooled up pretty decent but when it lit up all hell would break loose, it would spin the drag radials at 90mph.
IMO the HX50 is way too big for a 2.8 and the car won't be enjoyable unless it's WOT all the time or using it as drag car.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Originally posted by kamotors View PostI'm actually on a gt35equivalent Turbonetics, the big holset was very lazy and late to spool. HX50 would be way too big, I can hardly spool the gt35 below 4k. I creep up to 1 psi by 3500rpms.
Your reliability will be 100% up to your tuning abilities.
I'm at 18psi now and making over 400whp simply because I made a more aggressive tune.1997 540i/6 - stock
1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
Originally posted by Cyrix2k View Postthe h1c was lazy? My HX35 spools pretty well on a 2.5L M50... I don't drive the car hard so my latest log doesn't give an accurate number, but I have 7.5 psi boost @ 3473 rpms @ 46.9% throttle. 100% throttle in a high gear sees full boost far earlier and I'll creep into boost by 1400 rpms.1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
Originally posted by stanhayward View PostWhat cm^2 is your turbine housing. Is it twin scroll?1997 540i/6 - stock
H1c was very lazy, it was much bigger than my gt35, it was the large h1c with the antisurge inlet and huge turbine housing.
7speedshop.com
630's and a PTE 6262 turbo with a billet comp wheel will out flow a 35r by 30%. MS or VEMS.84 318, 86 325ES, 85 325E. 89 325IS,
89 BMW 325is Turbo - 8.02@85mph 1/8th
90 VW Golf, 01 VW TDI Jetta
98 VW GTI VR6 - 11.679@117.58mph Timeslip
96 VW GTI VR6 - 7.63@97mph
www.lugtronic.com
