Only on start and after revving it smokes a bit
My low milage turbo Prep
What color?1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
I'm at 18psi on metric blues. A resused set at that. Over 20k miles clocked.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
You could do what I did if you wanna make a quick spooling 250 on the cheaper side of things....It's 24lb injectors, a volvo turbo & intercooler, and a retuned stock chip. It took a little fiddling with the afm but it's running great. Stock hg and bolts, although I will probably switch to ARPs as soon as I can.
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
Originally posted by AbsorbantNut View PostYou could do what I did if you wanna make a quick spooling 250 on the cheaper side of things....It's 24lb injectors, a volvo turbo & intercooler, and a retuned stock chip. It took a little fiddling with the afm but it's running great. Stock hg and bolts, although I will probably switch to ARPs as soon as I can.
Me deatails
