My low milage turbo Prep
    Originally posted by edsel1134 View Post
    Specs.. Parts list or part numbers :) I already have head studs.. How mch boost can that turbo hold? Possible to get 300hp safely out of it?
    Well I got the turbo off of a eighties 760 volvo, its .52 on the cold side, unsure about the hot side but it's much larger than my old .42 hotside turbo. I'm running 12 psi and it has the potential for more, but I wouldn't be able to give you an exact number. It spools around 2k RPMs. I use an ebay bleeder style boost controller. Used miscellaneous saab, volvo, & whatever else is in the junkyard for inter cooler couplings, so not too many part numbers. I bought my oil feed line off of ebay; it is a braided SS hose with a m12x1.5 banjo on one side and an autometer 2277 fitting on the other to get it to thread into the block. Tapped the pan & used barbed garden hose fittings with some large flat washers, it's all explained in my build thread.
    If you're interested here's a link to it:Click Me
    Hopefully it's possible with a new OEM headgasket, arp studs, and more boost; that's what I'm shooting for:pimp:
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
