ive asked a few m20 turbo questions before... but the one answer I haven't come across yet is the issue of the AFM delete once the set up is put together. Ive read a lot of builds and gone through all the pictures, and obviously the AFM gets removed, but what is everyone using in its place? are yall using a MAF sensor somewhere in the tubing? or is this taken care of in some other part of the tune? does the wide band have anything to do with it? not trying to be a noob... just really confused..
possibly a dumb m20 turbo question...
not many here even know what a haltech is. im pretty sure it uses a vacuum source and an iat sensor as well why not google it?Comment
You can delete your AFM when using haltech ps2000 ..Comment
The Haltech is most likely designed to be used as a Speed Density (SD) or Alpha-N calibration like most other units.
Speed Density uses RPM and manifold pressure to determine fuel and ignition requirements
Alpha-N uses RPM and throttle position to determine fuel and ignition requirements.
Most cars will use SD as Alpha-N is mostly reserved for race only cars with ITB or radical cams.-Nick
M42 on VEMSComment
1987 Delphin 325e Sedan - Natalie
1990 325i 24v
1997 Chevrolet K1500 Crew Cab 4x4 - The CenturionComment
i realize that it would be a tuning nightmare. i just thought it would be unique thats all. but im throwing out the boost idea for the time being and just gonna keep her N/A for the time being.10 minutes... then we invade China.
We'll begin with the small town of General Tso's,
And move to the Orange chicken province.Comment
I'm wondering why you want the haltech. Seems like your not even familiar with its functions.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
im going haltech cuz i want to get rid of the e30 dash. ive done my research and after reading about all the headaches ppl here and other forums have had with megasquirt i thought this would be a good route to go.10 minutes... then we invade China.
Contact whodwho on either r3v or e30tech. He will set you up with megasquirt. It comes with no headaches as he has amazing customer service.Comment
A Haltech setup is $$$$$$$$$$$$$, and probably way more than you need to spend to meet your goals well. There are plug-&-play Megasquirt kits for the M20 out there. It USED to be a kludged-together system, but these days MSIII is really a heck of a platform for its price. You may also want to look at VEMS. While it is not open source like MS, it has built-in coil drivers and a built-in wide-band O2 sensor controller. With the MS, you would need something like the LC-2 for a wide-band (which you SHOULD be looking at using) and an external coil igniter.Comment
