From knowing nothing to having a Thunderbird supercharger on an m20b27i
  • Ether-D
    • Sep 2011
    • 2838
    #706
    Got the head back. It's oh so shiny. I'll be putting the rockers and shafts back in tonight with a complimentary valve adjustment. Then slap it on the bottom end I've been dicking about with for the last two months. Feels good to be making some damn progress.
    Originally posted by Andy.B
    I was born on 3/25…
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #707
      Originally posted by Ether-D
      Tell you the truth, I'm a little nervous letting anyone else touch my car. Even if they are a pro.
      To add fuel to the fire... just because someone is a "pro" doesn't mean he's good at his job.
      Took a friend's Mjata to the only guy in the state who still tunes the TEC2 he's had in the car for 15+ years... The guy was a fucking moron and hacked up the O2 sensor wiring, as well as setting the upper HALF of the load table for 12.5 AFR and other "I'm too lazy to actually tune this engine" level of stupidity. Be VERY careful when picking a tuner.
      • Ether-D
        • Sep 2011
        • 2838
        #708
        Right. This is what I'm afraid of.
        I was born on 3/25…
        • Ether-D
          • Sep 2011
          • 2838
          #709
          The head is assembled and on the block.
          God-damn it's pretty.
          I was born on 3/25…
          • Ether-D
            • Sep 2011
            • 2838
            #710
            A few more pics:
            I was born on 3/25…
            • Ether-D
              • Sep 2011
              • 2838
              #711
              Pulled the ole vert into the "shop" today. It looked like this:
              Cussed and screamed and farted. Then it looked like this:
              Farted some more. It looked like this:
              (F)Artsy shot:
              I was born on 3/25…
              • Ether-D
                • Sep 2011
                • 2838
                #712
                Broken motor mount and trans mount on the driver's side. Ordered new ones. I also ordered a new clutch. Sachs pressure plate (made in Germany) and fx racing kevlar somethingorother disc (made in USA) for $200. The combo is rated at 305hp and about the same tq. That should be plenty.
                I was born on 3/25…
                  • Jun 2010
                  • 2796
                  #713
                  Mad Torx, j0!
                  • goarmy
                    • Nov 2011
                    • 622
                    #714
                    Great way to show love to the M20 ;)
                    • Andy.B
                      • Sep 2011
                      • 1650
                      #715
                      Woohoo. Making progress!!!!
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #716
                        Some interesting vehicles in this...
                        I was born on 3/25…
                        • Ether-D
                          • Sep 2011
                          • 2838
                          #717
                          This evening I put the intake and exhaust manifolds onto the new motor. Also painted a bunch of brackets and such. I'm about sick of painting…
                          I was born on 3/25…
                          • Ether-D
                            • Sep 2011
                            • 2838
                            #718
                            So, the timing belt is on and I was turning the motor over by hand with a breaker bar and I'd swear that I was feeling one cylinder with lower compression. So instead of just checking the compression, I fretted and pissed and whined and was all "I'm just gonna not check the compression and I'm just gonna install this damn thing because I've been working on it too damn long to have to pull it all apart and redo it now". But my good buddies known to you as Chondamax and Agent here on r3v, said I had to check and if I didn't, I was a moo-ron. So I did and this is what I got:
                            1
                            2
                            3
                            4
                            5
                            6
                            So I was glad. Thanks again AndyB. and Swanny!!
                            I was born on 3/25…
                            • LJ851
                              • 7918
                              #719
                              It appears you need to recalibrate your elbow.
                              Lorin
                              The M30 is God's engine.
                              • Ether-D
                                • Sep 2011
                                • 2838
                                #720
                                I zeroed it out so it should be back in calibration.
                                I was born on 3/25…
