what wastegates are we running on here?
  • DJLimes
    • Dec 2013
    • 49
    I was looking at the tial 44mm for my setup. What do you guys run?
    87' 325is Wife
    09' cbr600rr Mistress
  • sayed ali
    • 762
    Perfect choice .. off course if it's a "REAL" tial ..
    I'm using a Turbosmart Ultra 38mm with no issues and good results ..
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • marco 325 a
      • May 2011
      • 83
      Waste gate
      I'm also using a turbosmart wastegate ultra 38mm work great for my set up
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        tial 38mm, yet to see how well it goes.
        Originally posted by priapism
        Originally posted by shameson
        • codrum
          • Jan 2011
          • 279
          tial 38mm as well. I use a vband adapter since the 666 manifold uses the old style flange while the wastegate is a Tial MVS. No problems so far with a 13lb spring and a homemade boost controller holding right at 15psi.
          • jaywood
            • Jul 2010
            • 4528
            Tial 38 seems very common as do the 44mm
            • Q5Quint
              • Jan 2005
              • 725
              I used a knockoff 38mm and it worked fine. I enjoyed gambling my entire engine with a $60 part instead of a $260 because I also had megasquirt with overboost protection. I would get spark cuts before my boost went higher than I wanted.
              If you dont have that system I would go for $$ quality.
              • blasphemy101
                • Apr 2012
                • 170
                Running a wyntonm ebay gate here. It has worked fine for 7k miles. That doesn't sound like much, but the car is only used for high-speed auto-x, so those are really hard miles.
                Overboost protection works perfectly with megasquirt.
                The Great Big M20 Timing Belt DIY
                Some good information I've found online (no affiliation):
                Turbo Tech (Garrett)
                Four-cycle information and cam properties for beginners (ISKY Racing Cams)
                • IronFreak
                  • Dec 2012
                  • 3702
                  I'm using dual 38mm Emusa gates. Haven't had them on the car yet but I have a few friends with LS/turbo setups that use thing with no issues. They actually come with a 1 year warranty. not bad for $70 a piece.
                  Instagram @rebellionforge
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    Used a Tial 44 for the last 5 years i think without any issues or maint :)
                    But i need a bigger now so i got a PPF 60mm.
                    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                    E30 M50 6 spd 764whp @ 24psi.
                    E30 M20 6 spd 675whp.
                    • DJLimes
                      • Dec 2013
                      • 49
                      Never heard of these before, how do they compare to the tial ones?
                      87' 325is Wife
                      • IronFreak
                        • Dec 2012
                        • 3702
                        Knock off for sure, and probably not a pretty, but they function well. the v-band clamps look more on the cheap side but still strong. I'm going to take lapping compound to all the v-band flanges before final install.
                        • 808e30325i
                          • 537
                          I'm using a 44mm Tial MV-R on a 666, the quality is second to none Imo.
                          • mrcheezle19
                            • Apr 2012
                            • 1451
                            synapse for me. Awesome quality with no issues at all so far.
                            Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
                            • yamahammer
                              • Aug 2012
                              • 350
                              I run twin mv-r 44's. I am pleased with them, all the components used in the assembly are pretty nice.
                              If you want some insight on changing the springs I can describe the method I always use as it can be tricky and you don't want to strip the threads in the body when you are aligning and tightening the aluminum cap on.
