External wastegate turbo suggestions?
  • Batz
    • Aug 2013
    • 303
    So, im fairly new to turbos and FI in general. So if you guys will see a lot of stupid questions from me on this forum in the future couple month, i apologize.
    Anyways, i cant seem to find a turbo. I want something with external wastegate, spools fast, and cheap. (Probably seems unrealistic, huh?) I have been thinking about getting holset h1c, but its a big turbo and ill have pretty big lag, which i dont want. Hx35 are only internal wastegated i believe? so are hy35.? Garrett are expensive.
    while doing my reseach i stumped upon this site, it has some turbos, some fast spooling external wastegate turbos, but the prices seem a bit suspicion. so i assumed they are bad? http://www.speedyracer.com/turbochar...d-Turbocharger
  • Specialedbob
    • Aug 2014
    • 11
    hx35w has an internal wastegate. hx35 does not have an internal wastegate.
    • Batz
      • Aug 2013
      • 303
      Oh really? will be looking for one with no wastegate then. It's just that the only ones I saw for sale on eBay and etc. were internal so I figured... Thanks a lot!
      • DirtyMaxTJ
        • Jun 2013
        • 146
        A lot of people on this site have had good luck finding them on cummins forums. I would say search there.
        • Batz
          • Aug 2013
          • 303
          yeah, i realized that ebay doesnt do much unless you get lucky, so ill probably search on truck forums and maybe even at junk yards... who knows..
          • GunMetalGrey
            • Dec 2010
            • 1499
            Aren't the internal gates on those set for 28+ psi? You can't use a boost controller to lower the spring pressure.
            Also, I am not sure which engine you have, but I don't think you will fit a turbo with an internal wastegate on a 24v. I had to shave the wastegate brackets off of my HX35 just to get it to clear the valve cover.
            • DER E30
              • Sep 2013
              • 2347
              Just gonna have to run 28+PSI!
              -Christian
              • GunMetalGrey
                • Dec 2010
                • 1499
                94 17 psi HX35W 12
                95-98 17 psi HX35W 12
                96-98 23 psi HX35W 12
                98-00 ETC 20.8 psi HX35W 12
                01 ETC 23 psi HX35W 12
                01 ETH 26 psi HX35W 12
                My number was a tad off
                • nomansland92
                  • 1657
                  I have a brand new hx35 with no wastegate, im thinking about selling it to up grade to ball bearing. If your interested I can try to find the one I want then I can sell this one.
                  IX being restored here
                  Ix turbo build here
                  • Batz
                    • Aug 2013
                    • 303
                    Pmed
                    • BMWManiac
                      • Dec 2010
                      • 1091
                      What size is your Hx35? CM^12?
                      1997 Artic Silver M3
                      CES GT4094r 651hp/615tq @ 24 psi
