FPR for BOOST
  • jules325i
    • Jul 2011
    • 353
    FPR for BOOST
    can i use the standard 3 Bar Fuel pressure regulator or do I need a rising rate regulator.
    Ill be running 2.8 m20 15PSI 80lb Injectors and E85.
    329i
  • Northern
    I like cupcakes & sh!tboxes
    • 5259
    Standard FPR if you have a standalone or another method of fuel control. I assume you do with that setup haha
    Originally posted by priapism
    Originally posted by shameson
      • 34844
      no you don't want a rising rate regulator, you want an aftermarket computer that can handle boost and E85.
      • dirtie30
        • Jun 2013
        • 28
        I would suggest a pnp MS setup along with a 1:1 FRP. Static fuel pressure isn't ideal for boosted setups, but of course that all depends on the tuning.
          • 34844
          a standard FPR is 1:1. ;)
          • dirtie30
            • Jun 2013
            • 28
            huh. The stock FPR looks like a standard rising rate fuel pressure regulator to me, not a true 1:1. Interesting.
              • 34844
              no. it's 1:1. all standard FPRs are 1:1. this keeps the fuel pressure at the injector constant relative to manifold pressure. it's necessary to keep the fuel output linear which is what the computer will always expect.
              a RRFPR would have a ratio like 1:5, 1:8, etc. this makes fuel injector response non-linear, which is a bad idea. RRFPRs haven't been a good idea for a decade at least. They were a decent band aid solution before you could build a standalone for $200 but they're pointless now.
              • dirtie30
                • Jun 2013
                • 28
                No shit, that's why I suggested a 1:1 because the stock unit looks almost identical to all the old VW RRFPRs I've messed with, so I just assumed it was rising rate.
                • jules325i
                  • Jul 2011
                  • 353
                  Ok yes I have a link g4plus xtreme ecu.
                  Thanks for the input.
                  329i
                  • jules325i
                    • Jul 2011
                    • 353
                    I'll post some pictures and dyno results when the car is finished, by the end of the year.
                    329i
