What size flange do I have on my turbo???
  • e3irsty
    • Jan 2014
    • 134
    I bought a hx35g that I thought was t4 exhaust flange size or whatever. It will not fit my TCD manifold and it is so frustrating to just find this out? The stud holes are 3.5 inches away from each other on the turbo, measuring from the center of one hole to the center of the other. T4 is 3.25 inches. So what the hell do I have?!?!?!?!?! Thank you for any help
  • IronFreak
    • Dec 2012
    • 3702
    It's Magic!
    Instagram @rebellionforge
    • e3irsty
      • Jan 2014
      • 134
      Thanks for the help lol. Already have done that haha a lot of that. Here's a picture of the turbo flange and the second picture is the manifold which is like every t4 3,25inches while the turbo is exactly 3,5 inches which I have not found anything like it. So confused
      • Northern
        I like cupcakes & sh!tboxes
        • 5231
        Looks awfully close to a T3. I think HX35's are usually T3 anyway?
        Originally posted by priapism
        Originally posted by shameson
        • e3irsty
          • Jan 2014
          • 134
          A t3 is closer to that t4 than my turbo neither are t3. The turbo holes I am measuring in the top picture are wider than a t4 so I am lost. It makes no sense
          • Jaxx_
            • Dec 2009
            • 1880
            edit: fuck what I said, I just saw that your flange measurements.
            editedit: is it internal wastegate? What other info do you have on the turbo?
            • e3irsty
              • Jan 2014
              • 134
              It's got an internal wastegate. Hx35g all I know really. Got it off ebay guy said pulled off a truck that was totaled there's no shaft play that's pretty much why I really got it
              Also the picture makes the turbo flange look gigantic. Measuring the holes horizontally in those photos the measurements are the same. The flange on the turbo is just a little wider which fucks it all up
              • kistler#7
                • Jun 2013
                • 186
                The bolts being 3.5" on center is similar to Holset's weird flange for their vgt turbo's. Check out the he431ve for sale on here:
                3.5" on center. T4's are usually 3.25 like your manifold.
                There's probably an adapter from the cummins guys, but if you wanted to get DIY on it you could gasket match the housing and the collector, then clamp the turbo to the manifold and drill new mounting holes into the exhaust housing.
                m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
                http://www.r3vlimited.com/board/showthread.php?t=338818
                • e3irsty
                  • Jan 2014
                  • 134
                  Could you explain this clamping procedure a little more please. And that is great to hear. I'm glad I know more about what I have. Thank you very much
                  • e3irsty
                    • Jan 2014
                    • 134
                    THIS IS EXACTLY WHAT MY TURBO IS!!!! exact same look, NOT T4 though I think that guy probably learned later on too lol
                    • e3irsty
                      • Jan 2014
                      • 134
                      http://www.ebay.com/itm/HX52-T4I-Hol...-/131321438275 found a flange to put my turbo on the manifold. Thanks again Kistler!
                      • kistler#7
                        • Jun 2013
                        • 186
                        You bet. Man $100 for the plate though, I might just drill it out. And but clamping I meant once you grind the turbine inlet to match the manifold collector, line them up and clamp it together how it would be bolted. Then drill out the turbo flange for t4 bolt holes.
                        I haven't done this before, but that's how I would go about making it line up
                        • e3irsty
                          • Jan 2014
                          • 134
                          Thanks again, I ordered it because I am fed up with getting this turbo on and that's the only spot I'm hung up on with this build then its pretty much plug and play haha definitely is a good idea though, my plan was just to use a stone and a dremel to grind the holes over more. Would've been a pain though, hopefully this helps someone else out in the future. Now on I am always measuring the flange first when I get a turbo
