O.K.Who Has done it..?
  • The Sly
    • 31
    Lots of you guys has done the 2.7 stroker but i want to know who has done the stroker with the 81mm eta crank with 130mm eta rods and i pistons to match the i head to also get 10 to 1 compression....
    THanks all
    • 34839
    I don't think that combo works.
    • The Sly
      • 31
      WEll i did it and it works really well but i want to know if anyone else has done it.
        • 34839
        dyno graph? how many miles you got on it? did you machine your pistons down?
        • The Sly
          • 31
          Listen NANDO i want to know if anyone else has done it.
          You sound like my mother with all the questions.
          • James Crivellone
            Head Janitor
            • 6303
            Because the point of this forum is to share information with each other.
            Not to give a smartass reply when somebody asks you more details about the reliability of the motor.
            • The Sly
              • 31
              Oh now the server administrator is telling me that i give smartass answers...
              I think i might be at the wrong place then..sorry for the inconvenience guys..
              • bwanac
                • 3354
                I have not done it... but I am interested in knowing more about yours.
                • The Sly
                  • 31
                  Now that sounds better.
                  I will be glad to tell you ...But before i do, i am just looking to find out if any of the guys have done something similar...
                  THanks bwanac
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    The new guy puts his foot down. lol
                    Will
                    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                    Welcome e30 (brilliantrot '90 325is) 12/23/06
                    DaveCN = Old Man
                    My signature picture was taken by ME! Not by anyone else!
                    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • Sean
                      • 5793
                      Dude, the reason Nando asked how reliable it was is because it's kind of a sketchy route to go. Shaving down the I pistons really makes the crown of the piston quite small. It brings the valve reliefs dangerously close to going right though.
                      It's just an all around risky thing to do.
                      Ususally you're suppose to use I-rods - aren't you, with this? Using eta rods would make it way too short. (maybe i'm mistaken?)
                      - Sean Hayes
                      • AdironRider
                        • Dec 2004
                        • 3491
                        This thread has the potential to be great.
                        Back to my roots
                          • 34839
                          what is your problem? I just wanted to know how you accomplished it, and what kind of power you were putting down.
                          • rs4pro3
                            • 5808
                            It is the same as the "i" engine ...as long as you have the timing marks at the proper location.
                            On my Stroker i got a Super ETA Bottom-End ..rebuilt the whole thing with many mods and i installed it all with the "i" engine head and all other i" engine parts ...
                            THe only thing different for the timing is that because i shaved the head 1.5mm, it was not dead on the timing mark. bvut very very close...So i have some timing retard which is good at high RPM...
                            I got the head chambers redone to fit the pistons in for a higher compression...which is about 10.8 to 1..295/295 cam ...fully ported head and intake..E36 injectors Lightweight flywheel with a 6 puck racing clutch..I also got some weight off the connecting rods then rebalanced...I also got a spacer with the Oil pump spring to increaser the Oil pressure...specially because i run it at 7000rpm quite often and do want lots of Oil on that cast crank....
                            Hope you like your setup...I find it pulls hard all the way to 7000rpm but after a while i wanted more...Good thing i have N.O.S.
                            Have Fun
                            [url]http://us.f1.yahoofs.com/users/b60fcfd6/bc/auto/__sr_/IM000584.jpg?phBiBqABvaNaDFCw[/rl]
                            Or at least that was his old setup.
                            85 325e 2.7 ITB'd stroker
                            • german g
                              • Feb 2006
                              • 1608
                              what a dickhead.....
                              "give me info, but you can have none of mine"
                              90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
                              :firehop:
