Manifold Bolts
  • yellow325ix
    • 18
    Manifold Bolts
    What bolts to i need for a precision 6262 to the manifold? I can't find the right size for the two inside holes. Seems the head of the bold runs into the turbo itself so I can't get it lined up straight to start it.
  • downforce22
    • Aug 2009
    • 3192
    if you lift the turbo up then start the bolts there is enough room to get it started and after a few turns you can set the turbo down and just tighten like normal
    • yellow325ix
      • 18
      Do I need something like this instead of a regular bolt?
      • nomansland92
        • 1657
        Yes use a stud, check your thread pitch before you order though.
        IX being restored here
        Ix turbo build here
        • yellow325ix
          • 18
          Thx!
