M20 Turbo. Which oil to use?
  • Nitro Nick
    • Jan 2014
    • 268
    Hey guys,
    I'm trying to button up my turbo project and am trying to figure out which type of oil and coolant to use.
    When I was N/A I was running synthetic 10w30 or 40 I believe...sorry shes been down for a bit. I know I should be running something thicker.
    I have heard of people using 20W50 and 15W50
    Was wondering what brands and if its synthetic or not.
    Also, what type if any special coolants are guys running?
    Thanks,
  • Garage30
    • Aug 2015
    • 123
    I ran synth 20w50 in mine, same as bmw says in the manual but synthetic. If it gets cold syn 10w40 would be better.
    Euro car and parts export business based in the Netherlands, specialized in E30 Tourings!
    Instagram: @garage30_ WWW.GARAGE30.NL
    • grinchxvx
      • Dec 2015
      • 295
      I run Mobil 1 0w-40 in my 135i, they run hot as hell and that oil works great in it. Had an oil analysis done at 95000 miles with 3000-5000 oil changes and it came back perfect
      • Nitro Nick
        • Jan 2014
        • 268
        I grabbed some 20w50 VR1 synthetic. Ill see how that goes. And I grabbed the peak global coolant since that popped up a few times during some research.
        • BMWManiac
          • Dec 2010
          • 1091
          Rotella 15w40
          1997 Artic Silver M3
          CES GT4094r 651hp/615tq @ 24 psi
            • 37833
            I run Valvoline VR1 20w50 in all of my M20 engines including the boosted one.
            Grover Beach, California
            BimmerHeads.com
            • Nitro Nick
              • Jan 2014
              • 268
              The synthetic im guessing right?
              • ccsdo5
                • Mar 2013
                • 708
                I personally use the normal one just because it is cheaper and I buy a case at a time, but 20w-50 VR1 FTW!!
                -Dee
                5-lugged turbo 318is Barn car
                IG: @deebelmont
                • kevine30
                  • Feb 2014
                  • 150
                  I use the same for my turbo m20. non synthetic.
                  2003.5 Slicktop Silver-grey M3 6 speed
                  Individual Blue Onyx 1988 528e -2.7i turbo (sold)
                  1998 328i (sold)
                  91 318is -24v Swap (sold)
                  • reelizmpro
                    • 9558
                    rotella t synthetic 5w-40 primarily.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                      • 37833
                      Non-synthetic.
                      BimmerHeads.com
                      • jim325
                        • 228
                        VR1 20w50 non synthetic in my m30b34 turbo since rebuild. Usually change it every 4000 miles.
                        89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
                        • Nitro Nick
                          • Jan 2014
                          • 268
                          Non-synthetic.
                          Would that be negative for the engine since I have been running synthetic before hand. I thought switching to non synthetic after running syn for a while is a no no...
                          • digger
                            • Nov 2005
                            • 6198
                            run some cheap non synthetic for 5-10min to flush the synthetic out then put the oil you want
                            • E30-Ellerman
                              • Oct 2015
                              • 212
                              Bumping an old thread. Just ordered the VR1 20w50 synthetic for my turbo m20 build.
                              Any reason you guys run non synthetic in your boosted cars? And to the OP, how was the VR1 20w50 synth?
                              2016 F-150
                              1987 Royalblau 325es B25 turbocharged
                              Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
