oil pressure question for turbo
  • e38740imd
    • Jan 2015
    • 43
    im turboing an m30 car. what do you guys use to get the oem oil pressure switch, oil pressure sender and oil temp?
    looking for something similar to this
    • 34844
    There are many choices, but many oil pressure senders also have a second post for the oil pressure dummy light switch. the VDO kit for example does. And since you don't need the oil pressure switch anymore, you can put the temp sensor in that location (the VDO temp sensor has the same thread and screws right into the block).
    • nomansland92
      • 1657
      I use a sandwich plate for the filter, supports the turbo, pressure and temperature sensor
      Sent from my SAMSUNG-SM-G891A using Tapatalk
      IX being restored here
      Ix turbo build here
      • e38740imd
        • Jan 2015
        • 43
        do you have a link to the right one? I have a b35 engine
        • nomansland92
          • 1657
          Never mind haha I forgot m30's use a cartridge oil filter.
          Ix turbo build here
          • e38740imd
            • Jan 2015
            • 43
            I was about to say. this could be good!
            the search continues
            • TimeMachinE30
              • Jun 2014
              • 3749
              That gives you two.
              ACS S3 Build / Dinan 5 E34
