E30 M52b28 turbo build
  • Deanswaim1
    • Oct 2016
    • 17
    Okay guess its getting to the point on my build where mainfold is getting needed. Any recommendations of a good not over priced mainfold. Or anyone have one forsale?;)
  • E30-Ellerman
    • Oct 2015
    • 212
    From research, they're tricky to make/do correctly due to the wider DOHC m50. If I were in your boat, I'd save up the $500 to get a properly made one by rapid spool which has been suggested by many members. Worry free, quality product.
    I'm about 50% done my turbo m20 build/install and what I've learnt is getting quality products off the bat, saves a lot of headache and most of the time money in the end. Go with the one listed below!
    I'm sorry I can't provide first hand experience with it, doesn't seem like many people are wanting to or able to provide much assistance in this topic as my question below yours has gone days without any help.
    2016 F-150
    1987 Royalblau 325es B25 turbocharged
    Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
    • Deanswaim1
      • Oct 2016
      • 17
      Yeah they have good stuff, I've been in contact with them but I was just looking around. Yeah I had a built m20 I sold a while back because I decided to change platforms ll. Excited to get her done tho. Hoping someone is selling a used on haha.
      • E30-Ellerman
        • Oct 2015
        • 212
        Ahh nice, good luck, hopefully you can find one!
        2016 F-150
        • Good & Tight
          • Apr 2004
          • 2057
          http://www.rapidspoolindustries.com/ordering
          Thanks for plug, manifold pricing has been updated on our website.
          We've added the E36 top mount to our line up and will be adding some more turbo accessories.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • Maad325
            • Jan 2013
            • 132
            subbed as ill be boosting my 2.8 soon also
            • wat3rbug
              • Jul 2017
              • 23
              Subbed
              Also subbed as I will join the boosted club in a few months also.
              :popcorn:
              • ba114
                • Sep 2015
                • 364
                Check out my build thread in my Sig. All done with rsi manifold
                RHD OBD2 M50b25 turbo build thread:
                http://www.r3vlimited.com/board/showthread.php?t=384800
                • JOMARO
                  • Mar 2006
                  • 116
                  be ware that the 24V e30 RSI mani , creeps boost
                  • ba114
                    • Sep 2015
                    • 364
                    Its fine if you run over 20psi ;)
                    • haaken675
                      • Sep 2016
                      • 601
                      How would boost creep from a manifold? Maybe if your wastegate isn't working properly I could see that...
                      • K-Line
                        • Sep 2013
                        • 122
                        I can also confirm that it creeps significantly, wg tube is positioned horribly. needs to be modified
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5253
                          WG placement on the manifold is mostly to blame. Given the lack of space, it's the only real way to add a wastegate to the manifold.
                          That said, you could block off the manifold's WG port and install the wastegate on the turbine housing and that would solve everything, but not everyone wants to cut/weld their shiny new turbine housing, and then possibly do it again if they change turbos.
                          at 12psi on an S257, I haven't had creep yet. If that changes, I'll probably do this mod.
                          Originally posted by priapism
                          Originally posted by shameson
