Source for flow matched injectors
  • citizen_insane
    • Jan 2013
    • 216
    I like the idea of running the plug and play Siemens Deka 60lb injectors, but I can't seem to find anywhere that both confirms fitment & will flow match.
    Anyone aware of a source or have a specific P/N I can reference?
    I've seen the ones on the kamotors website, but they do not appear to be flow matched and ±6% is not something I'm comfortable with. Also not really interested in knockoffs or clones, fuel isn't somewhere I'm willing to cut corners to save money.
  • digger
    • Nov 2005
    • 6216
    Fiveomotorsport might be able to help
    • citizen_insane
      • Jan 2013
      • 216
      Thanks. I've actually already been discussing with them. I'm probably going to go with these: https://www.fiveo-racing.com/product...t=23102852291/.
      I also found there are Injector Dynamics ID725's which will fit, but they are quite a bit more expensive.
      • digger
        • Nov 2005
        • 6216
        these also work, they can also cut the slot for the clips to
        • citizen_insane
          • Jan 2013
          • 216
          Anyone got any information on the difference between the Bosch EV6 and EV14? I assume the EV14 is just a newer design? I'm guessing the EV14 is newer and therefore better, but I have not data to back that up.
          • digger
            • Nov 2005
            • 6216
            Afaik It's the body and connector but some ev14 have the ev1 mini timer connector I don't know of the internal differences . I'd focus on the spray pattern (spray cone angle) you don't want injectors with a split pattern for 4V or a wide angle. A single cone around 20* won't hit the relatively cold port walls iirc and thus won't turn into liquid it'll hit the hot valve or even better go into the hot combustion chamber . If you run sequential then run the pulse timed such that fuel is injected into moving air as much as you can.
            I recently listened to this and it kind of confirmed what I've been thinking
            The first 18 min you can skip over
            • Misinformed Youth
              • Mar 2018
              • 30
              So your telling me not to run my $80 for all 6 "Deka 80's" I found on ebay? lol (Not sarcasm)
              • citizen_insane
                • Jan 2013
                • 216
                It's your build. I don't know your budget, but in my opinion you usually get what you paid for and I'm not willing to risk my engine on knock off parts.
