Bottom mounted turbo setups
  • Schlander
    • Dec 2016
    • 26
    Hi guys
    Does anyone have knowledge about builds with bottom mounted turbo setup on either M20 or M50 engines in an E30?
    Daniel
  • Jaxx_
    • Dec 2009
    • 1880
    As you might imagine, many are interested in top mounting because bottom mount puts the turbo in a place that requires a scavenging pump for the oil return.
    If I'm not mistaken, BMW did a bottom mount turbo on the 2002 turbos, but I'm sure that doesn't help you at all.
    • downforce22
      • Aug 2009
      • 3192
      TCD has one for the m20
      turbochargingdynamics.com is available for sale! Check it out on ExpiredDomains.com. turbochargingdynamics.com is in high demand, secure it today!
      • Schlander
        • Dec 2016
        • 26
        Thanks guys :)
        How high above the floor pan is the turbo required to sit, without use of a scavenging pump?
        • haaken675
          • Sep 2016
          • 601
          Typically above the oil line in the pan...
          • silnc
            • Feb 2015
            • 90
            Currently developing one that puts the turbo high enough Sent from my Moto G (5) Plus using Tapatalk
