DIY Turbo install in progress
  • White Nightmare
    • Jul 2006
    • 376
    #31
    For engine cooling reasons it makes more sense to have cold/cooler are released into the engine bay rather than hot.
    -Chris
    Big Brain- "The big brain am winning again! I am the greetest! Now I am leaving earth for no raison!"
    - California Certified Smog Technician -
    • matt
      • 3732
      #32
      -Chris
      Not really.
      • Mr Deagle
        • 1121
        #33
        -Chris
        especially when there is a near red hot or red hot exhaust heating things up
        /sarcasm
        it wouldn't help at all, the radiator handles cooling duties
        • Marvin
          • Jan 2004
          • 58
          #34
          Updates........
          Received more parts for the turbo
          Finally got a chance to remove oilpan
          Here's after cleaning it up
          Guages installed
          Update pics of the turbo install
          More pics to come......
          Marvin
          89 325ic
          89 325i
          03 baby girl
          San Jose, CAlifornia
          • mops
            • Jan 2006
            • 138
            #35
            Heya. I'm preparing for my build aswell. do you still have front vallance out ? I need the exact measurments of the interncooler area. I see you used IC with 2.5" ends, is that because 3" wont fit ? I'm aplnning on mounting the IC the same way you do. However I'm concerned about the airflow there (or rather lack of it - it's behind the bumper and vallance and in my case rego plate, etc)... what are you doing with oil cooler ? relocating it somewhere or what ?
            • JOE BMW
              • May 2005
              • 346
              #36
              Looks good man...Good luck
              Keep us posted
              www.ZeppieriMotorsport.com
              • chivas
                • Sep 2006
                • 119
                #37
                Quick question as i just got my iX out of the dead.... is this possible with the iX? will the oil pan and other differences in the iX make your great write-up different? if so, what parts?
                i also like to know what you are doing about fuel and engine management.
                thanks!! great post and very inspirational. love how you priced out most of the things. gives building this project a good budgeting idea.
                • ACHTUNG
                  • May 2005
                  • 2397
                  #38
                  Great thread!
                  1989 US E30 Cammed S52
                  Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                  • skatebline
                    • Sep 2006
                    • 167
                    #39
                    keep up the good work!
                    • norwood e30
                      • Mar 2007
                      • 442
                      #40
                      What Sizes Are Your Oil Feed And Return Lines Man Because Im Getting Ready To Put My T3 In My Car This Summer. If You Can Give Me On Some Advise I Could Really Use It Right About Now.
                      • Marvin
                        • Jan 2004
                        • 58
                        #41
                        Hi there,
                        Im using -4an for the oil feed line and -10an for the drain line
                        Marvin
                        89 325ic
                        89 325i
                        03 baby girl
                        • Eric
                          • 5142
                          #42
                          what are you doing for electronics?
                          • bimmer8604
                            • 3017
                            #43
                            Originally posted by Mako18
                            I plan to weld a small bead around my charge pipes where I use couplers to help prevent any chance of blowing one off. Might be overkill...
                            -D
                            called a bead roller...
                            And i would put the BOV closer to the turbo, too. If you look at it, hot air is exiting the turbo, going into the intercooler. When you put that hot air into the cooler, it heats the cooler up OMG! rocket science i tell ya!
                            Very nice write up, can't wait to see more on how you run your lines and whatnot. I really enjoy the itemized parts lists you've been including, as that can be confusing some times. What will you be doing for engine management?
                            Kyle
                            1988 M3, 97 840, 99 XJ
                            DILLIGAF
                            • Mr Deagle
                              • 1121
                              #44
                              Originally posted by Marvin
                              Swap the shiny coupler in the first pic with the shiny coupler/bov in the second pic
                              Kyle
                              Thank you!
                              and did you work for loren?
                              • bimmer8604
                                • 3017
                                #45
                                yea, i worked for him for a while. i dont think i was the best employee(dunno what he would say if somebody asked him, heh) but i lovvvvvvvvvvvvvvved it there.
                                kyle
                                DILLIGAF
