DIY Turbo install in progress
  • blueapplesoda
    • Dec 2005
    • 1904
    #46
    for oil llines......ball bearing turbos only need at most -3 an....journal bearing and other non bb turbos can use -3an or -4 an....my small t3/t4 smokes with -4 at high rpm, so i put a small piece of -3 inline of my -4 line to "restrict" the oil feed.
    • kylebes1
      • May 2004
      • 2804
      #47
      [quote=Mr Deagle;721695]Swap the shiny coupler in the first pic with the shiny coupler/bov in the second pic
      quote]
      Why would you put the BOV on the intake side of the turbo?
      • Mr Deagle
        • 1121
        #48
        [quote=kylebes1;732293]
        quote]
        *looks again*
        an honest mistake, i thought it was on the compressor discharge
        • matt
          • 3731
          #49
          You can also use a restrictor that fits in one of the fittings in the line. We made one in a lathe and drill press for the wreck racing car.
          • iNetForce
            • Mar 2007
            • 82
            #50
            Awesome DIY! It shows that you have experience, clean up!
            I was amazed about the idea of having the BOV closer to the turbo. The first and last turbo setup I did I put the bov just next to the TB.
            The learning process never stops, will put it next to the turbo next time!
            • e30 power
              • Mar 2006
              • 413
              #51
              nice man
              whats done to the motor???
              8)8)
              • nineohfour
                • 245
                #52
                the BOV should be as close to th TB as possible, after all thats the main part it's there to protect.
                • Fuel4blood
                  • 15
                  #53
                  Subscribed, super informative thread. Can't wait to see the finished product. Thanks for taking the time to write this up. Your bimmer looks nice as well.
                  • 88driftIS
                    • 300
                    #54
                    The bov needs to be as close to the tb as possible. This is where the pressure first starts to build. I know it's only split second difference but having it closer to the tb will get rid of the air faster and more efficiently. Or you could just run two bov's.
                    • 88driftIS
                      • 300
                      #55
                      damn just noticed how old this thread is...
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        #56
                        yeah that works too, and is what i eventually did. i just had the parts laying around at first so it works.
                        you can buy a -4an male to a -3an female from any AN parts supplier. or through me haha.
                        Derek
                        • blueapplesoda
                          • Dec 2005
                          • 1904
                          #57
                          it don't matter how old the thread is we add more info than its good.
                          • wwwayn
                            • 22
                            #58
                            any more infor.how's the car now.
                            • E30Eric
                              • Sep 2007
                              • 157
                              #59
                              Nice setup! How was the mani only 379? It says 490 on the 666fab website. I will be ordering one soon myself.
                              1988SuperETA|Full I component swap|19lb injectors|Schrick 272|MSIIExtraBeta20071020|GM DIS Wasted Spark|LC-1
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #60
                                Holy old thread batman! 1yr and no updates?
                                The main reason one would desire to put the BOV closest to the TB is to keep the air moving in the same direction, rather than reverting off the TB throttle plate back to where ever the BOV is mounted. Either way it works just fine, since it's there to keep the revision from making it all the way back to the compressor wheel.
                                john@m20guru.com
                                Links:
