M20B27 Forced Induction Injectors
  • DBaker
    • Jul 2020
    • 1
    Hey guys I am in need of larger injectors for my 1986 325. I recently did a turbo kit on my car running 8psi and I am unable to find upgraded injectors for my car. What other injectors work in a M20? looking for maybe 36lbs injectors. Thanks!
  • citizen_insane
    • Jan 2013
    • 216
    Bosch EV-14 long body injectors are direct drop in (at least on my 1989 M20B25). I got mine from fiveomotorsports because they were able to provide flow matching to 1%. It looks like the injectors I was running are no longer linked on their website (prob just due to moving the product pages around), but if you reach out to them by email, I found them to be pretty helpful. I know a lot of guys run Ford injectors since I think they ran EV-14s stock, but getting a random set of OE injectors won't guarantee that they're flow balanced. Prob not an issue if you're not worried about maximizing how much power you make and can just run a bit rich to compensate. Personally I was too sketched out by injector variability not to have a data sheet showing that they'd been flow matched.
    • benjamin
      • 174
      Hey guys, I'm in a similar situation to DBaker, so I figured I would just tack onto this post rather then make a new thread.
      I'm collecting parts to turbo my 1985 "327i." I was told by a guy that has done numerous turbo m20's, that the Injector Dynamics ID1050X 14MM purple top hats work really well. Can anyone confirm if they will fit?
      • digger
        • Nov 2005
        • 6216
        what ECU are you using? i know there is a difference between high impedance and low impedance but cant remember which way compatibility works and doesn't work
        • JehTehsus
          • Dec 2019
          • 269
          ID has the CAD drawings available for all their 1050's - and there are a few variations - if you are running stock fuel rail just quickly measure the stock injector length.
          I have them with a nuke rail and they fit fine (I mean, the giant nuke rail doesn't really fit fine in the stock manifold, but the injectors are fine).
