m10 rebuild
  • shoguncro
    • May 2011
    • 115
    m10 rebuild
    I have a m10 and he needs a rebuild i will change all gaskets, change all pistons and stuff.
    doesn someone have a diy ?
    thanks
  • NineEleven
    • Jun 2011
    • 12
    Look for a Haynes manual. You need specific tools to put the pistons back in. Also if you want to changes valves you need a specific tool. I don't know the names sorry
    • Holland
      • Nov 2008
      • 7212
      I would look around some of the 2002 forums, as this engine is a staple for those cars.
      Originally posted by DEV0 E30
      • Hey_You
        • Nov 2009
        • 963
        You need a piston ring compression tool, the big 'C-Clamp' style valve spring compressor to begin with. Don't start this until you have those tools. There is a pdf file somewhere on how to overhaul your engine. I have it on my toolbar on my computer at home. I'll post it up when I get on it.
        85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
        • Hey_You
          • Nov 2009
          • 963
          I'm pretty sure this has what you need to know, I think
          Repair Manual
          • shoguncro
            • May 2011
            • 115
            Thanks
            The head is rebuilded , payed 120$ for that
            The piston compresion tools is 20$, but i will borow it from my friend
            all gasket have been oredered OEm from munchen
            thanks for the manual
            • TobyB
              • 5297
              Measure the pistons carefully- the ring gaps wear pretty quickly.
              And the skirts (lower sides) of the pistons do too, and get scraped up.
              The bores seldom do.
              DO change the rings.
              And bearings are cheap, relative to your time.
              Oil pumps are NOT, but check yours carefully if you reuse it.
              hth
              t
              • thebutterson
                • 463
                In case you still haven't found a good diy here's a link: http://www.bmw2002faq.com/content/view/85/32/
                • Hey_You
                  • Nov 2009
                  • 963
                  And if you are too lazy to look, 45 ft/lb for the main bearing caps, 40 ft/lb for the rods. Those are the important ones, Will post head torque tomorrow (in ft/lb not rotation degrees)
                  • shoguncro
                    • May 2011
                    • 115
                    hth
                    t
                    hi a friend will do the measures, becouse he works with engines every day
                    Still waiting :)
                    thanks guys
                    • Hey_You
                      • Nov 2009
                      • 963
                      Haha, sorry, I just torqued my head down today (was waiting on new bolt washers). I forgot to log on at work, but I'm pretty sure it was 30 ft/lb, then 50 ft/lb, then 60 ft/lb, then 60 again (it was 59 instead of 60, but I went ahead with the extra). Let it sit a few minutes between each torque cycle to give the bolts a little time to stretch. I'm waiting until tomorrow morning to give it the final 60 ft/lb torque.
                      MAKE SURE YOU CLEAN ALL THE OIL/SLUDGE OUT OF YOUR HEAD BOLT HOLES OR YOU CAN CRACK YOUR BLOCK WHILE TORQUING!
