M10 knowledge.
  • E30_Pare
    • 7801
    M10 knowledge.
    318i Database
    We need a collective database of 318i m10 know how!
    Backround History
    Wiki e30
    Wiki M10
    318i M10 Maintenance
    Real OEM 318i Diagrams
    http://realoem.com/bmw/partgrp.do?mo...4&mospid=47302
    Barry Burrs Tuning Guide
    Setting TDC
    318i M10 Electrical
    All You Need To Know About L-Jetronic
    HPSI Motorsports is an industry leading manufacturer specializing high quality silicone hose kits for engine performance and longevity.
    02 FAQ
    http://www.bmw2002faq.com/content/category/3/15/32/
    318i Modding
    EDIS, Megasquirt, ITB's, MAF
    Lightened Flywheels
    M10 Parts
    BluntTech 318i Parts
    http://www.blunttech.com/ShopbyVehic...up=AAA&mode=PG
    EDIS, Megasquirt, M20 TB Parts
    M10 Oil Pan Baffle
    http://www.racetep.com/oilpan.html
    IE M10 Internals
    http://www.iemotorsport.com/bmw/2002-engine.html
    Megasquirt Management
    http://www.diyautotune.com
    M10 Builds
    S14 ITBs, EDIS, Boost
    http://www.e30tech.com/forum/showthr...t=51098&page=2
    Hey_You's M10 Build
    http://www.r3vlimited.com/board/showthread.php?t=224770
    HSV Turbo Build
    M10/12 F1 Build
    http://gurneyflap.com/bmwturbof1engine.html
    UNDER CONSTRUCTION
    DREWLIENTE
    1$ PShops PM me
  • SkiFree
    • Jun 2011
    • 2766
    ADAMS Autosport
    • E30_Pare
      • 7801
      Edit - moved to top
      DREWLIENTE
      1$ PShops PM me
      • TobyB
        • 5293
        www.bmw2002faq.com
        t
        • Hey_You
          • Nov 2009
          • 963
          ^----repost, but I think it should be listed twice. If you can't learn everything you need to know from that site, then you probably shouldn't be trying to modify/maintain your m10
          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
          • E30_Pare
            • 7801
            ^^^ agreed.
            We need turbo builds!!
            Probably one of my fav m10 builds. You have to go through all pages to reall enjoy it.
            M10 ->s14 itbs -> mega squirt+edis ->boost
            DREWLIENTE
            1$ PShops PM me
            • solo318
              • Jun 2012
              • 183
              I have done a few turbo builds. My current race car is a turbo m10 with 48mm ITBs 292 cam and a 60 trim t3. MSnS extra. I have been driving and racing m10 engines for 15 years. Check out my shop web site Stephensmotorworks.com
              • E30_Pare
                • 7801
                I've got a boost question. I know the older 2liter blocks are mostly forged. Would I be able to just throw a 318 head on the 2liter block & boost with stock internals? Does the 318 head on 2l block have lower compression with stock sized head gasket?
                DREWLIENTE
                1$ PShops PM me
                • thebutterson
                  • 463
                  This has been covered many times on every m10 related forum out there search. Short answer: it bolts up, lower compression, incorrect combustion chamber for pistons.
                  • E30_Pare
                    • 7801
                    Yea I know it's been covered. To lazy to google. Easier to just ask, but thanks! Thats what I needed to know.
                    DREWLIENTE
                    1$ PShops PM me
                    • Hey_You
                      • Nov 2009
                      • 963
                      Didn't even need to google, I have a built thread for this. I'm running a 2.0L block with Piano Pistons and a 318i head. No issues, good increase in torque (I actually notice it, could be because the new rings/bearings) but I need to give it a cam, and throw some boost at it.
                      Solo318: How do you like the 292 cam? Is it driveable in the lower RPM range?
                      • E30_Pare
                        • 7801
                        For sure il check it out. Im looking at a similar setup. Are u planing to upgrade to m20 throttle body? Are you going to change up to arp headbolts & mls gasket 4 turbo? Or are u going to boost as is? Why did u opt for the piano tops rather than the flat top pistons? I hear good things from the 284/292 cams when it comes to boost. When it comes down to like 316 cams or hot cams in general there is no power under 4k NA. So wouldn't be very street able. Or reasonable for a DD Boost, but at the same time I hear that in some cases stock cam is best for boost
                        DREWLIENTE
                        1$ PShops PM me
                        • Hey_You
                          • Nov 2009
                          • 963
                          I will run studs, but leave the stock HG until I get the tune down solid. I would rather blow a headgasket than a cylinder. I bought the shortblock with the pistons already in it. Decided I would give it a try. I will be leaving the stock m10 throttle body on there.
                          • E30_Pare
                            • 7801
                            Das interesting. Good point bout the HG. Il keep that in mind when I do my build. What did your block come out of? 2002 I assume? I think the 320 block had flat tops & I could source flat tops out of an m30. What is your compression at? Oh and aren't you worried the m10 tb would be a bottle neck? I think it is like 44mm compared to the m20 60mm & they have adapters available.
                            DREWLIENTE
                            1$ PShops PM me
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              Duration is generally not good for boost, but lift is. Obviously you need the motor to flow a little if you're forcing air into it, but this is the reason a factory cam sometimes is better. Most options for M10 cams are for NA, which work "okay" for turbo applications. Some people have done the schrick 304 and turbo, but for myself I plan on sticking to the factory cam. If you have a big turbo and it needs to spool, then matching the cam with it might be something to consider.
