I think I'm pretty screwed...
  • Young_Enthusiast
    • Jun 2013
    • 19
    I think I posted this in the wrong section, so I'll post it here instead.
    Hi everyone,
    So last month I bought my first car, a 1985 318i. To make a long story short, it's been off the road for over a week because of a leaking heater hose. Now when I say leaking, I mean like a fountain. I figured that this would be an easy fix--just buy a new hose and be done with it. Unfortunately, it seems like the part has been discontinued or something because I cant find it anywhere. The hoses I need are all the ones attached to the additional thermostat. If anyone has any advice, that would be great. I need to get back on the road!
  • TobyB
    • 5280
    Ditch the additional thermostat. They're a pain.
    Or:
    go make a pest of yourself at a good, local, non- chain auto parts store.
    After some sweettalking, they'll let you look at all the gnarly little hoses
    that are available- you'll most likely find something close enough to work right.
    If you take in the old one, often the crustier older guy will come back with something
    that you'll be able to make work- often, a short section of a longer hose...
    Or:
    Call Blunt.
    t
    • mitchlikesbikes
      • Dec 2013
      • 858
      Or:
      Or:
      Call Blunt.
      t
      x2
      IG: @mitchlikesbikes
      • thebutterson
        • 463
        Try looking up the part number at this site: http://www.realoem.com/bmw/select.do . E30's are under the archive section.
        Then call a local dealership with the part number or go here http://www.pelicanparts.com/. You should be able to find anything you need.
        • gettinscurvy
          • Jun 2013
          • 164
          heh, I threw away that thermostat and the assorted hoses on Monday. Went straight tubin'
          • Smelser
            • Feb 2011
            • 633
            straight tube with heater hose, role the windows down in the summer, the heat wont radiate too badly. not like my MACK wich has a garden style valve to turn the flow off.
            sigpic1984 318i Total conversion to a DIRT race car.
            Check out our build on facebook @ www.facebook.com/brewstermotorsports
            • Young_Enthusiast
              • Jun 2013
              • 19
              Thanks everyone, I got the hose and everything from someone on here and all I have to do now is throw it on and cross my fingers.
              • gettinscurvy
                • Jun 2013
                • 164
                Best of luck! My issues might be solved as well when I get some new parts in on Tuesday
                Sent from my SCH-I545 using Tapatalk
                • Young_Enthusiast
                  • Jun 2013
                  • 19
                  Well, that did the job! Got the new assembly installed today and everything is back up and running.
