Best spark plugs to use?
  • ZomBAR15
    • Aug 2014
    • 103
    I tryed searching but couldnt come up with much. But...I added an mst blaster ss coil to my 318i m10 the other day and am looking to change out/upgrade plugs and wires next. What plugs would you guys recommend for good performance? Resistor type, non resistor type, brand, gap, etc..
  • Bullhead
    • Sep 2014
    • 532
    I was told by a BMW tech to always use just a solid core spark plug. Like an NGK plug, the cheaper one. Stay away from Bosch Platinum's imo.
    sigpic87 325E The Honey Badger
    • Bullhead
      • Sep 2014
      • 532
      Here are a few plugs considering you have a 91 318i?
      There are other's who will add to this but this is my opinion, I am fairly new to the m10 and m20 engines but have much experience in racing with small block Chevy engines. I have ran solid core plugs in 500hp drag motors with no problems and tried platinum plugs and they were terrible imo.
      • ZomBAR15
        • Aug 2014
        • 103
        Its an 84 318i
        • Smelser
          • Feb 2011
          • 633
          use the IE large wires (7 or 8MM) availible in different colours and we use NGK
          i think the plugs are like a bp6et or something. they have three ground electgrodes and the fat solid core to them. they work very nice for us
          sigpic1984 318i Total conversion to a DIRT race car.
          Check out our build on facebook @ www.facebook.com/brewstermotorsports
          • ZomBAR15
            • Aug 2014
            • 103
            Awesome. Thanks guys!
            • ZomBAR15
              • Aug 2014
              • 103
              You positive they are the bp6et?? Lol If so im about to order some.
              • TobyB
                • 5280
                In an M10 engine, NGK BP6ES, or BP6RES, if you're going to use low- impedance wires on a street car.
                All day, every day.
                t
                • ZomBAR15
                  • Aug 2014
                  • 103
                  Ok local part store had the bp6es's in stock so I just picked those up a little while ago. What is the best gap to set them at? Or should I leave them where they are preset?
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    I'm using ngk in the m30 and some diamond fires in the m20.
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • TobyB
                      • 5280
                      0.030's fine. They're usually a little less from the store, and that's ok too as long
                      as they're all about the same.
                      t
                      • nightbear
                        • Apr 2011
                        • 19
                        I would suggext using BKR type plugs instead of BPR - they are much easier because they use 14mm wrench.
                        • Smelser
                          • Feb 2011
                          • 633
                          just ordered 12 BP6ET's for the new season this year
                          • packratbimmer
                            • Dec 2009
                            • 1335
                            +1 ... BP6ET plugs work awesome - ran them for years in my stock 318i cars
