engine locked
  • Smelser
    • Feb 2011
    • 633
    engine locked
    Assembled the engine.
    New bearings, new rings.
    install the pistons and its locked up, remove two pistons, it turns over but is hard.
    remove one more and it can turn over normally.
    rings were gapped to each cyl.
    any ideas?
    sigpic1984 318i Total conversion to a DIRT race car.
    Check out our build on facebook @ www.facebook.com/brewstermotorsports
  • TobyB
    • 5297
    Assuming the crank spins easily with no pistons on it:
    You swapped caps on the rods
    Rod bearing clearances aren't right
    The pins are binding on the small ends of the rods,
    cocking the rods sideways slightly
    You dropped a beer bottle in there.
    I've done the rod cap thing. Man, I SWORE I knew better. Then I just swore.
    hth
    t
    • Smelser
      • Feb 2011
      • 633
      Rods tight to the crank. spins free now
      • TobyB
        • 5297
        what was it?
        t
