E30 M3 clutch in 318 M10 - help
  • Hyfly
    • Oct 2016
    • 9
    Hello everyone,
    I am looking for an answer from someone who has done this already.
    The question is... do I really need an 323 throwout bearing to have the setup working? Other say am 525 bearing will also work.
    I need an answer before I start this thing...
    My parts collection is so far this:
    - M3 E30 clutch disk
    - M3 E30 Pressureplate
    - 2002 228 flywheel
    Can someone help me?
    Regards Stefan
  • TobyB
    • 5297
    I used the 323 throwout with the 228 flywheel- when you compare the stack height
    of the 215 mm clutch cover and flywheel to the 228, it's quite a bit thicker.
    I would recommend it.
    t
    • Hyfly
      • Oct 2016
      • 9
      Hey Toby, thanks for your answer.
      At what hight is your clutch engaging with this setup?
      0-25%
      25-50%
      50-75%
      75%- above?
      At the moment my clutch is gone (215mm) and it is engaging at 80%...
      thanks!
      • TobyB
        • 5297
        About 25%. A nice high pedal, with plenty of travel after the 'knee' point of the diaphragm.
        It should self- adjust to that if everything's set up right.
        hth
        t
        • packratbimmer
          • Dec 2009
          • 1335
          I always used the 323i bearing with the 228 flywheel
