For engine management, i am using an EFI Euro 96. Stock stuff is out the window. Im running wasted spark with a bosch coil pack. Inside the engine is a stock S14 2.3 crank, s14 rods and mahle pistons out of the GT40. Schrick 304 cam, stock valves and seats. ARP head and main studs. Final displacement is 2.15 liters.
that turbo is just for mock up purposes, the real one is going to have a stage 5 exhaust housing, i really have no idea what the compressor side is going to be
any u guys cant possibly want those rims
oh and im not going to be using a late 80's snail for a turbo....modern garret stuff for me
I'm too lazy to calculate the bore, so tell me.
s14b23 crank has 84mm stroke?
I used custom 86mm crank and 92mm mahle pistons, but I have serious problems with cracking blocks.
I'm planing to use 90,5mm bore on my next engine, but stroke/bore ratio will not allow high rpms.
EDIT: I ran stock m10 rods.
Reason: Visible
Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01
Nice and clean lookin, I like the low mount setup. Will the oil drain without a pump?
Glad to see more people turbo the M10. What are your plans for the intake?
The intake will be ethier sheet aluminum/billet, or all billet...the turbo is going to have to drain into a catch can, then a porsche 930 scavenge pump driven off of the power steering pulley
also, there is going to be a wastegate, a porsche 930 unit, i need to get some pics up of the header in stainless
the m10 block cant accept M3 sized pistons, unless you get a good block, im assuming that that is the problem, we will have to wait for what he has to say
