High idle on my 1987 E30, what should I be looking at?
  • Keven
    • 27
    I just inherited a 87 E30, I got it to run but the idle is pretty high (tach is broken but I would guess around 3000 rpms). What could I look at to fix this problem?
  • Holland
    • Nov 2008
    • 7176
    Couldn't tell you, I have an M10 as well, and all I have is a bit of a rough idle.
    Originally posted by DEV0 E30
    • Danny
      • 14216
      Vacuum leaks?
      • kenika65
        • Aug 2007
        • 1336
        ICV adjusted yet?
        1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
        1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
        • Jean
          • 18228
          Your 87 came with an m10?
          High idle could be caused by many things:
          bad/stuck icv, vacuum leaks (hoses, gaskets, o-rings), bad icv module, even ecu, engine temp sensor.
          Was AFM / throttle cable maybe adjusted to result a high idle? Could be that too.
          Start checking the basics.
          • Keven
            • 27
            How do I check the ICV? And actually its an 84, and im a noob at these cars so excuse me if I picked the wrong subforum. Mods please move!
            • Joe318is
              • Sep 2005
              • 6451
              penny!
              try cleaning the ICV. to test, locate the ICV [round, pass side over the valve cover]
              Unplug it, if the idle dosent change its bad, if it changes but not much, then the ICV needs cleaned. Get some brake fluid cleaner and spray the shi out of the inside of the ICV, plug the ends and shake it aound. Should have a little 'tap' noise to it when its clean.
              if that dosent work, theres always the good old penny trick. take a few pennies, and drill a hole in each one. start with a 1/4" hole, then make a few larger, and a few smaller. place the penny in the vaccum line that comes from the intake bellows to the ICV [place the penny agaisnt the opening for the ICV] try 1/4" first. If the idle is too high, use a smaller hole, too low use a larger hole. Keep trying until the idle is around 650 to 700 rpm.
              WAAAAAAAAAYYYY cheaper than a new ICV
              Originally posted by vlad
              • Keven
                • 27
                Thanks Joe, ill let you know tomorrow!
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  trusty penny trick i never did get around to doing that to my '84 eta
                  '89 Alpine S52 with goodies
                  • e30trooper
                    • 11576
                    hey i unplugd mine and my idle went high, does that mean it works?
                    • Joe318is
                      • Sep 2005
                      • 6451
                      kinda. may need cleaned out
                      • e30trooper
                        • 11576
                        ok cool, im going to just replace all the hose lines cuz i know some are really old cuz they are hard as a rock. I bought some intake cleaner, a spray like BPC that should work good?
                        • Kerrath
                          • Jun 2008
                          • 577
                          I haven't messed around on an M10 to know this, but I know the throttle switch on Volvo 240s and M20's can be adjusted and can put the car in power mode even at 0 throttle. This throws the RPMs up to like 2-3k depending on how open it is. I know M50s have no adjustment screws so they can't be adjusted so its possible your M10 isn't adjustable either.
                          • e30trooper
                            • 11576
                            do you mean advanced timing? or maybe theres a screw on the intake somehwere i can ajust, this is my 1st bmw
                            • Kerrath
                              • Jun 2008
                              • 577
                              On the throttle body, there's a switch that rides on the shaft that opens and closes the butterfly valve. If the switch is adjustable (2 screws, one on either side of it that loosen it so you can rotate the switch) then it's possible to trip the switch so it tells the ECU that the throttle is open when in fact, the throttle is fully closed. When this happens, depending on the degree, it can make your idle be any where from 1500-3000rpm pretty easily. (I did this to my volvo accidentally when I adjusted it as close as possible for better throttle response. My friend's E30 started doing this also after we put the head back on. His is an M20 though.)
                              Since the ecu no longer thinks the engine is at idle, I'm pretty sure it wouldn't use your ICV any more. Unplugging it could get the valve partway open and delivering some extra air.
                              At any rate, even if it turns out not to be the problem, it's pretty easy to check out. With your engine off, pull the throttle lever on the throttle body gently. If the TPS is adjusted correctly, usually you will hear a click noise. Some TPS don't click though so without knowing much about m10s, I can't say for sure.
