High idle on my 1987 E30, what should I be looking at?
  • angelus5012
    • 89
    there an idle control screw on the side of the ICV. my idles at like 3k and it wont go down ;(
    • angelus5012
      • 89
      your icv could be on backwords? thats what was wrong with mine also spray some carb cleaner in there and use q-tips tp clean it
      • e30trooper
        • 11576
        well since this guy ^^^ bumped this age old thred I might as ask... can i use a ICV from a eta? My m10's idle is at 3k , the headers are glowing red, I found out my ICv is stuck open. Theres a rip in the hose to the ICV that sucks air in. If I open the rip bigger the idle goes down and the power range works fine. Also I unplugged the ICV and nothing changed. just an idea b4 i goto yards and look for a rare m10 icv.
        • ivopivo
          • Oct 2009
          • 66
          I'm having an idling issue right now (sometimes fine at 700-800, sometimes high at ~1200, sometimes jumps from 700-1200 as if someone's pressing and letting go of the gas continuously)... when I unplugged the ICV RPMs jumped to about 2000-2500 for 2 seconds, then went down to normal idle, maybe a bit less... does this mean it should be cleaned?
          As for the penny trick, does the penny go into the hole that's perpendicular to the ICV or the hole coming out of one end of it?
          Thanks
          Ivan
          • FetusGoulash
            • Apr 2009
            • 91
            Same problem here. but when unplugging the ISV it didnt idle as high as you mention. My exhaust has rusted off behind the car so i think loss of back pressure may also have an effect on the idle problem. but probably not the entire cause to it.
            I have been checking for vacuum leaks but cant find anything. I should replace all the lines to be sure
            • ivopivo
              • Oct 2009
              • 66
              I might have solved it, or at least made it better, by cleaning the ICV, throttle body and the intake box and also seafoam in gas tank as well as intake manifold.
              BTW... how important is the little plastic piece that goes inside the filter housing? I took it out when I cleaned everything and forgot to put it in when reinstalling.. car runs fine but wanna make sure...
              Ivan
              • Tico Frank
                • Feb 2011
                • 351
                Reviving this old ass thread. I just got an m10 that had an erratic idle but was buttery smooth above 3500 so I did the penny trick and it now sits at 900 rpm idle so I can confirm my ICV was/is dead. I found that the ideal size was between 1/4 and 1/8 for the hole.
                • SSR-125
                  • Jan 2014
                  • 578
                  While the car is running, take something like a screwdriver and give the icv a few taps and if the idle starts skipping around just replace that because that's what seemed to do it for me. Good luck
                  -chris
                  88' E30 325 24v Turbo Coupe
                  91' E30 325i Sedan
                  09' E82 135i Coupe (Sold)
                  01' E46 325ci Coupe (Sold)
                  97' E36 328is Coupe (Sold)
                  91' E30 325i m52 Coupe (Sold)
                  90' E30 325is Coupe (Sold)
                  90' E30 325ic Coupe (Sold)
                  88' E30 325is m20 Turbo Coupe (Sold)
                  88' E30 325 Coupe (Sold)
                  87' E30 325e Coupe (Sold)
                  86' E30 325es Coupe (Sold)
