I recently ordered an ARP head stud kit from Ireland engineering which specifies that their kit is different from the off the shelf M20 ARP kit and specify “62 ft/lb with ARP moly lube” as well as “consult the ARP instructions for complete info”
When I go to the ARP’s website they list “70 ft/lb with ARP ultra-torque fastener assembly lubricant” I also contacted ARP and they said both kits use ARP2000 bolts.
What torque spec do you guys go to? would it depends on the lubricant used?
https://tech.arp-bolts.com/instructions/201-4305.pdf
https://www.iemotorsport.com/product...-stud-kit-m20/
