Timeframe for tune-up?
  • Hartacus
    • Dec 2016
    • 44
    I did a full tune up plugs, wires, cap, etc about 4 years/ 8k miles ago. The car was sitting outside in the northeast the entire time. Should I replace anything? The engine has a vibration at idle and when going over 2500 rpms. Wasn't sure if it was the plugs or the motor mounts.
  • tomstin
    • Mar 2015
    • 569
    Cap, rotor and plugs for sure as they corrode just sitting in the elements. Take a look at the cooling hoses, fuel hoses and belts. They will also deteriorate with age. The gas is also probably bad causing the poor engine performance.
    2004 525i Manual - 1985 325E Coupe Manual
    • Hartacus
      • Dec 2016
      • 44
      I just ordered a new set of NGK plugs, ignition rotor, wireset, distributor cap, and ignition coil. Hopefully an overhaul will fix the issue. They are Duralast brand so hopefully that doesn't cause an issue.
      • It's Soda Not Pop
        • Jan 2022
        • 877
        Sometimes with duralast if you look at the label on the part it will be name brand and the box just says Duralast. But usually for parts I stick to name brand or tried true brands. But anything is better than corroded parts.
        88' Seta 2.7i Zinno
        https://www.r3vlimited.com/board/for...430-my-88-seta
        • Hartacus
          • Dec 2016
          • 44
          Thanks and you’re right. I canceled the order and went all Bosch.
