M20b25 to M20b27 swap troubles
  • TheGT12
    • Jun 2023
    • 1
    E30 Rookie here.
    Purchased 1990 325i from someone who was going to crush it, M20B25, 6 Button OBC, 173 ECU, Auto Trans. Non running and failed leak down test, timing belt had snapped prior to purchase. A friend of mine had a good running M20B27 Manual trans, 027 Mot. 1.0 ECU all from an 87 325e and I purchased it with intent to put it in the 325i chassis as finding an M20B25 on short notice proved difficult.
    Engine cranks, no spark or fuel. Using 325e harness and ECU. Using 325i auto trans starter to make use of the unloader switch inside of it. Crank trigger pin on flywheel was repaired but intact. 12v can be traced from the coil down to the pin inside the distributor cap but does not make it past the rotor. Fuel pump could NOT be heard throughout start attempts unless relay was jumped. With DME relay also jumped I tested the ECU connector and all power to the unit was good, grounds were good and ohms for the crank sensor and speed sensor were within spec. I’m at a loss, am I missing something that has to do with the different chassis? Any help appreciated. I’ve read many forums but I can’t seem to find help with this exact situation/idiotic swap. If I can’t make it run with the factory tech, I’ll be wiring a mega squirt and a switch panel but figured this was worth a shot.
  • Panici
    • Dec 2009
    • 2493
    Just confirming, you don't have fuel pump prime and also don't have spark off the coil when cranking?
    Sounds like the ECU is unhappy for sure.
    • tomstin
      • Mar 2015
      • 569
      Sounds like you have your hands full. First, get a copy of the wiring diagrams here: http://wedophones.com/Manuals/BMW/
      You may want a copy for the engine, and another for the body. Also, dig around for someone who swapped and B25 for a B27 as those wiring changes may give you a hint.
      ECU needs to see both reference sensor and speed sensor, make sure they didn't get swapped.
      In the wiring diagrams, the onboard computer (page 132 in my manual) is involved in the start circuit to the main relay. And I've heard of cars not starting with a bad onboard computer.
      With the fuel pumps not turning on, the ECU is not seeing something it wants. Time to start checking those circuits one at a time.
      Good luck with this project!
      2004 525i Manual - 1985 325E Coupe Manual
