Weak voltage to coil HELP
  • JRH
    • Aug 2023
    • 10
    Weak voltage to coil help
    I’ve been having a no start issue for a while now
    Background
    - getting fuel (pulled line and cranked)
    -weak/no spark (literally replaced whole ignition system including cps)
    - getting correct voltage to main relay
    - getting correct voltage to relevant dme pins
    (Pin 37 I have to jump main relay to get volts)
    - bypassed immobilizer
    -Cleaned grounds
    -charge battery
    Problem
    -I get weak/no spark directly from the coil I have connected a test light and I get a pulsing light but I don’t think I have enough voltage to trigger a spark from a plug
    - have noticed that I get 11.5v to my positive coil terminal and 6v to my negative coil terminal but have continuity from negative terminal to pin one Ecu and I have continuity from positive terminal to c101 connecter
    -I took off the dme connecter for testing and didn’t put it back and tested the coil (dme unplugged) and I was getting 12.6/battery voltage to my coil
    Could this be a sign of a bad dme or does anyone know what the problem might be I feel like I’m so close to figuring this out could anyone help here
    Thanks​
  • It's Soda Not Pop
    • Jan 2022
    • 877
    Great write up
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • TobyB
      • 5298
      well, that ain't right. the black wire should be at 12v, and the DME pulls it low
      only when it's 'charging' the coil to fire.
      If you're getting the same voltage on pin 1 on the DME, AND the DME grounds are good,
      then yep, something inside the tin can's not doing its thing.
      t
      • JRH
        • Aug 2023
        • 10
        Yea I bought a new one gets here today I’ll update
