Yet another M20 Stroker config question - CA SMOG legal setup
  • RicardoD
    • Nov 2023
    • 7
    Hello,
    I am planning to swap the M10 in my 1982 E21 to an M20B25 stroker as part of its overall restoration project. Looking to build a CA SMOG legal M20 using stock intake, injectors, ECU, new cat... This is for a fun to drive reliable street E21. I am not chasing peak horsepower.
    Option 1: 2.9L Mahle (2860cc)
    885 head with 272 cam (remember SMOG compliant)
    IE Mahle 2.9L Ultimate Street Stroker Piston (85mm bore)
    10:1 compression (new to work with 91 octane CA gas)
    84mm stroke crankshaft (M52 crank and 135mm rods)
    Option 2: 2.8L (2823cc)
    86mm bore with Custom Pistons (probably via Top End Performance)
    10:1 compression ratio
    81mm stroke crankshaft (325e crank)
    Anybody with any thoughts or opinions of these two options? I seen a few post indicating Option 2 works for SMOG with a properly rebuilt engine, ECU w/tune, and a new CAT (not one at its end of life from the donor E30). Option 1 probably similar.
    My E21 blog is here (just at the start of this project):
    All the best,
    Ricardo
  • digger
    • Nov 2005
    • 6105
    option 1,
    • RicardoD
      • Nov 2023
      • 7
      So this is essentially the same thread.
      I will update as I converge on a solution based upon conversations with different shops with E30 California SMOG experience.
      • digger
        • Nov 2005
        • 6105
        the important thing is the camshaft and tuning, the rest barely even matters
        the reason for option 1 was that its the better engine overall and wont impact in any meaningful way on SMOG
        • Rev Run D
          • Feb 2013
          • 392
          Can you chip-tune the 2.9? Assuming you can't megasquirt/standalone for smog.
          • digger
            • Nov 2005
            • 6105
            Yes you can. Quality of outcome will depend on the knowledge and ability of the tuner and to some extent fuel setup and overall maintenance/function of the engine electronics
            • RicardoD
              • Nov 2023
              • 7
              I think 272 cam is the most I would want to temp fate with. Even staying stock is an option. I like the Mahle MS piston setup and that would be my preferred path. In this specific case I will be going from a tired M10 in my E21 making maybe 90hp to a very fresh M20 motor with Motronic. I think I will notice a huge change in the performance of the car even if I stay entirely stock.
              And I will end up at the local California Air Resources Board (CARB) referee station undergoing a visual inspection and a tail pipe test since I am doing an engine swap. So visually everything should be stock along with all the E30 emission control bits. Bore, pistons, and crankshaft are obviously not visible.
              • digger
                • Nov 2005
                • 6105
                The stock camshaft is highly underrated for the street. If going with custom pistons then using the 81mm crank is a bit of a waste compared with 84mm and bigger than 84mm ought to be done with a bigger cam and itbs to maintain breathing so a 84 mm stroke is a reasonable compromise / sweet spot.
