325i cold idle routine
  • PEZ2
    • 50
    Quick question on the idle profile for a 325i on a cold start. My engine starts ( now) and revs to 1300 and drops to 750 in about 4 or 5 seconds. I don’t have a stock 325i to compare it too. It doesn’t behave like a “ modern” car or my 86 2.9l running M30B30 base software on a custom tune, where high cold idle is maintained and the drop to final idle can be minutes.
  • 82eye
    • Jan 2009
    • 2079
    smoke the car and fix any vacuum leaks. higher idle when cold is almost always a vacuum leak or two. it's common for things like intake gaskets to begin failing at this point causing small leaks as well.
    • PEZ2
      • 50
      Ok I will take it as a no, e30s do not have a “software” controlled high cold idle.
