Haltech Nexus S2 here. Does what I need and runs ITBs nicely. I tunned the idle in a similar fashion how stock Matronic does it, ICV never fully closed. My hot idle target is 900 rpm, ITBs set screw keeps the idle at 820 or so, Stock bosch ICV does the rest with being almost closed. Fully closed setting is 25% and I'm at 27%. Idles good considering 284 cam and ITBs. Ignition correction table and PIDs help to keep the idle on target and its ok in general all things considered, maybe 30-50 rpm or so as far as surge goes. Idle ignition sits around 10-12 adv and keepa the engine nice and not super hot.
I was given a suggestion to actually meet the target with the set screw = ICV fully closed and keep ICV for cold starts only. Any thermal expansion in ITBs and idle change should be taken care by idle error timing correction table... in theory. More stable idle?
How do you guys do it and what's your thoughts?
