Mark D 6900RPM chip vs stock rockers
  • funcrew
    • Jun 2007
    • 1223
    Engine is a stock M20B25. What's the likelihood I'll blow up the stock rockers by raising the redline from 6500RPM to 6900RPM? I autocross, so the rev limiter does get used a bit.
    If the chances are not favorable, what's the minimum rocker upgrade that will be reliable at that level?
    Any other issues I should be thinking about?
    Thanks!
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • Hallen
    • 1008
    I asked Mard D that question and he wasn't concerned about it at all. That's all I know on the subject.
    1987 E30 325is
    1999 E46 323i
    RIP 1994 E32 740iL
    oo=[][]=oo
      • 34836
      your rockers are more likely to fail just from old age and fatigue, poor adjustment or $shifting than they are from a high redline.
      also, for autox I'd rather have a much higher redline and avoid bouncing off the limit, rather than one that forces me to hammer on it for long periods of time. That's part of why I set mine over 7,000.
      • Hallen
        • 1008
        Yep...
        More info on it. Blipping over the red line and $shifts along with weak springs cause a lot of them. RPM's alone don't always do it. That guy whill really knows what he is talking about, trust me.
        1987 E30 325is
        1999 E46 323i
        RIP 1994 E32 740iL
        oo=[][]=oo
        • e30cbe
          • Jun 2007
          • 46
          Thanks!
          From what i know many pattern rockers do not have the quality of oem rockers - i know a few who have raced pretty wild m20s and oe rockers have not posed problems at much higher rpms than standard - also the cam lift and valve spring pressures have a lot of bearing on the reliability of rockers not to mention usage style - miss shifts etc
          • Erick
            Official R3V Drifter
            • 11169
            Curious argument, because I never had any luck with going past 6500rpm. My motors were in very good shape, which if you're correct, then my valve adjustments (.010 cold) must have been the problem.
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
              • 34836
              what's good shape though?
              and a lot of the rockers had poor castings with big holes in them. Worn springs will also contribute (valve float).
              • e30 gangsta
                • 3877
                I had the 7100 rpm chip for over 4 years. With multiple track days i never saw a issue.
