excessive valve ticking, kinda loud
  • Rockinlittle325i
    • 341
    Ok so I'm driving around town and I did a few rain doughnuts for shits and giggles
    well I start to hear the valves a little louder than usual a little after the event,
    I've already driven about 25 or so miles since I noticed it, and it's been a full day too, so I'm guessing nothing huge to the point of needing to pray but I'm a little worried
    I did a valve adjustment on friday so is there any common mistakes I could have done?
    what should I look for when I pop off the valve cover/
    You have Honda = I talk shit
  • SpecM
    • Oct 2005
    • 4531
    broken rockers
    if all are intact, re-set them and report back
    1989 cirrisblau-metallic 325i
    • Rockinlittle325i
      • 341
      I'll check a little later today, then if all's good set them tomorrow?
      any other possibilities? how common are broken rockers?
      say if I do have a broken rocker what could go wrong with that?
      • SpecM
        • Oct 2005
        • 4531
        pretty common, its happen to half of us one time or another
        if you have a boken rocker, it should be replaced ASAP. Your car will run on 5 cylinders, and in the mentime you should not drive it or at least disconnect the injector to prevent fuel wash/dilution.
        • Rockinlittle325i
          • 341
          well mine runs just fine, and just as smooth as before,
          do I have to take the head off to replace the rocker?
          • gtdragon980
            • Jun 2008
            • 1808
            Depends on the location of the rocker. I broke two on the 6th cylinder and I managed to replace them without removing the head...it was a bitch pulling the rocker shafts out though. If its any other cylinder im pretty sure you'll have to pull the head. Definately inspect the other rockers while you're in there also! Good Luck
            FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
            Originally posted by scabzzzz
            I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
            1989 325i - Project/weekend driver
            2002 325i - DD
            2005 Suzuki SV650 - Toy
              • 34844
              check for stripped eccentric nuts.. they don't take a lot of torque and strip pretty easily.
              and double check your adjustments. it could be one or two came loose.
              basically open up the valve cover and have a look, it only takes about 5 minutes. ;)
              p.s. you do not need to remove the head to replace the rockers. you can do all 12 in the car.
              • SpecM
                • Oct 2005
                • 4531
                how? I've been thinking... how do you pull the shafts out?
                  • 34844
                  undo the tension on all 12 rockers. they slide out pretty easy after that. you can use a flathead in the grooves where the "key" at the front of the head goes to get you started.
                  • gtdragon980
                    • Jun 2008
                    • 1808
                    really? but is there enough space to pull the shafts out far enough for the rockers in the front of the engine to come out??
                    2002 325i - DD
                      • 34844
                      yes, either remove the radiator or jack up the front of the motor.
                      • SpecM
                        • Oct 2005
                        • 4531
                        the radiator would be out anyway to remove the timing belt
                          • 34844
                          nope. I think I've only done it that way once.
                          • Rockinlittle325i
                            • 341
                            Checked the rockers, they aren't broken, I'm going to re-adjust them when the weather clears up
                            Thank God
                            • thereisnoyun
                              • Feb 2007
                              • 2301
                              check to see if all the rocker holding clips in the right place, my pop off once, and it sounded like a broken rocker arm. They should be pretty tight, if they are lose they need to be replaced.
