Hi i have an 89 325i and i am having a problem diagnosing the trouble.
ok the car has a 2.7 out of an earlier car(i did not do this and i have another 2.5 that im building for the car) anyway the car will only start sometimes. when it doesnt start if i open the hood and unplug the idle control valve and spray starting fluid in it, it will usually start. Sometimes i have to repeat the process 3 0r 4 times. Now i have replaced the icv, mass air, pludgs, adjusted valves, checked for vaccum leaks and relaced the fuel pressure regulator. No luck! In my research i ehaved learned that the 2.7 is supposed to have a cold start valve and mine does not, but could that be the cause?? also i have noticded the 2.5 cars have 2 fuel pumps, one in tank and one in line, my car only has the in tank one the fuel pressure was in spec when tested, but could it not be on initial prime.
usually after driving the car it will start righ up, but sometimes it wont, or it will start and then sound like it runs outta gas and ill have to pop the hood and unplug and spray again.
Sorry for the long ass post, but ive been trying to figure it out 4 a while. Any help is appreciated
Scott
my car
Scott
my car
