fuel system woes
  • gwb72tii
    • Nov 2005
    • 3864
    fuel system woes
    thought i had a bad fuel pump as the pump would stop at random, and then if i smacked the cover it would start back up. pretty interesting when you're tooling along the freeway to have the car motor die.
    so i install a brand new oem pump, and the problem is still there. its like the pump will create enough fuel pressure to start the car, but then quit pumping and starve the motor.
    fyi the feul pump relay is brand new as well.
    dme relay?
    “There is nothing government can give you that it hasn’t taken from you in the first place”
    Sir Winston Churchill
  • BTP325ic
    • Apr 2009
    • 700
    prob the DME i have had the some prob and replaced that and it fixed my problem now i need a ICV b/c not my idle is every were and wont hold idle.
      Replace the main and fuel pump relay. If the problem is still present use a test light or meter to find out if power at the pump is going away. If it isn't, pull the pump and see it there's a layer of sediment in the bottom of the tank. If there is it may be getting sucked up onto the inlet screen and choking off flow.
      • gwb72tii
        • Nov 2005
        • 3864
        both relays are new.
        problem still there with a new main relay
        should the ICV "buzz" with the ignition key on?
          • 34847
          yes
          • gwb72tii
            • Nov 2005
            • 3864
            ok, update
            the fuel pump will initially pressurize the system as the car will start as normal and idle smoothly.
            it then dies as apparently the fuel pump i guess is not operating other than the initial pressurization sequence.
            once the car starts, what sensor(s) then takes over and operates the pump?
            TIA
              • 34847
              the ECU keeps the relay grounded as long as it sees a crank signal, there are no other requirements.
              • gwb72tii
                • Nov 2005
                • 3864
                so the crank position sensor, otherwise known as the pulse generator, may be the culprit, or a ground gone bad?
                  • 34847
                  if the sensor was that bad then it probably wouldn't start at all. you can test it, supposed to be 540ohms +/-. Grounds or a bad ECU seem more likely.
                  • gwb72tii
                    • Nov 2005
                    • 3864
                    thanks for the help
