Miller maf
  • kamotors
    • Nov 2007
    • 7102
    #76
    Originally posted by theox69
    Excuses, excuses...
    Where's the video already?:D
    I'm still packing the stuff I need to ship, If I don't have a video by the end of today then......I won't have a video by the end of today.:p
    7speedshop.com
    • kishg
      • Sep 2006
      • 2624
      #77
      yeah.. kamotors is really slacking off on this stuff :)
      '12 F30 328i Sport Line
      '91 SpecE30 #523
      '00 Ford F-350 Dually Tow Vehicle
      BMWCCA #360858 NASA #
      128290
      • Liam
        • 753
        #78
        Originally posted by kamotors
        I also just noticed the Liam has a different version of the maf with a pig tail for the connector. The one I got is a direct plug and play and has the connector right on the maf.
        The longer I run this MAF the better I like it.
        I had considered distributing them but that's not going to happen (my end the guys at Miller are great, I'm just done with that end of business).
        So far I've run it (without any other tweaks) for about what now... Couple of months?
        Definite A+ upgrade to the nasty old M20s worth every penny.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        • theox69
          • May 2008
          • 1732
          #79
          Maybe slacking off isn't exactly what he's doing instead of posting this clip...
          you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
          • kamotors
            • Nov 2007
            • 7102
            #80
            well I'm back but the only clip i recorded got corrupted, so I'll just go a record a rev up video in the garage:(
            but heres proof that I actually went:)
            7speedshop.com
            • kamotors
              • Nov 2007
              • 7102
              #81
              uploading quick garage video now.
              warning camera can't record bass, but its super bassy in person.
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                #82
                okay, just a super quick poopy video, sounds way better in real life
                7speedshop.com
                • sticksdaman
                  • Apr 2005
                  • 2987
                  #83
                  thanks alot! The car is silent! Just how I like it.
                  Originally posted by ebelements
                  Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                  • theox69
                    • May 2008
                    • 1732
                    #84
                    Wow, that sounds good.
                    I need to pick that up ASAP!
                    • thereisnoyun
                      • Feb 2007
                      • 2301
                      #85
                      What if I want to use the 17.5 will the stock miller maf that's tune for 14lb? I dont want to use the stock injectors and I'm kind of afraid to get the 19lb injectors; considering if MAF is the only upgrade. I migth have cold start issues when it comes winter if I use the 19lb.
                        • 34847
                        #86
                        if you get the W.A.R. chip it doesn't matter, just retune for the different injectors. same thing for cold starts (you can tune those, right?).
                        • kishg
                          • Sep 2006
                          • 2624
                          #87
                          sounds good.
                          '91 SpecE30 #523
                          128290
                          • thereisnoyun
                            • Feb 2007
                            • 2301
                            #88
                            this I know, I just dont see my self fiddling with it. I would just want to put it in and have it work... aka. dont want to spend the extra 300 on teh war chip :P just wondering.
                            • T Verdier
                              • Aug 2007
                              • 2636
                              #89
                              Then you'll never be alble do any heavy moding on your motor without buying a new chip
                              I have 17lbs injectors sitting on my dinning room table. I can put them in when I want. But I won't need a new chip because I spent the extra $300. And when I get a cam I won't have to get a new chip because I spent the extra $300. But if you aren't planning to put that much into your m20 then I probably wouldn't spend the extra $300.
                              • kishg
                                • Sep 2006
                                • 2624
                                #90
                                when a chip is $200 and this allows you to do so much more, it's a no brainer to get the war chip i think.
                                '91 SpecE30 #523
                                128290
