Miller maf
  • digger
    • Nov 2005
    • 6213
    #121
    Originally posted by u3b3rg33k
    Eventually, and sort of. Also, each time your battery dies, or gets disconnected, you start from square one.
    but how often does that actually happen, rarely in my experience?
    • digger
      • Nov 2005
      • 6213
      #122
      Originally posted by Sharino
      Not true, you can run a stock car with the 19# injectors, the DME will self adjust. It improves fuel economy as it has a better atomization rate/spray pattern.
      i have used 19# and it did not improve economy over a recondition set of stock ones, it all sounds good in theory though.
      Given that most e30 owners are cheap its not an unreasonable thing to do, but far from ideal, they are as big as i would use on a stock engine.
      • u3b3rg33k
        • Jan 2010
        • 2452
        #123
        It usually happens right after my car passes tech, and the negative terminal is just loose enough that everything shuts off when I turn the key. Probably the worst time for your car to have to re-learn that it's injectors are 5# too big.
        Ich gehöre nicht zur Baader-Meinhof Gruppe
        Originally posted by Top Gear
        Just imagine waking up and remembering you're Mexican.
        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
          • 37834
          #124
          People need to stop putting 19's in stock motors. The M50 17's are the perfect upgrade and you don't need more than that.
          Grover Beach, California
          BimmerHeads.com
          • AnimalE30
            • Aug 2009
            • 266
            #125
            Alright, so the 17lb injectors will work fine with the M20, after the car adjusts to them?
            Would buying a FPR,and turning the fuel pressure down a notch help? I think the stock FPR is set up for 3.5 bar or something? so run 19/17lb at 3.0 bar?
            Ive just been gathering bits and pieces of information from a bunch of different threads. Let me know if i'm completely wrong.
            Sorry for the thread jack.
            • digger
              • Nov 2005
              • 6213
              #126
              actually you don't need more than the stock ones, just make sure they are good..........easily the best option.
              • digger
                • Nov 2005
                • 6213
                #127
                Motronic should have no dramas running 17lb but why do you need even them on a stockish M20? Alpina used stock ones for more than 200hp
                no use getting an adjustable FPR complete waste of money, and stock is 3b B25 and 2.5b B27
                • LowR3V'in
                  • 4209
                  #128
                  There's a dyno of a stock m20 running mustang 19# yellow tops.
                  I think his air fuel ratio was in the 10:1.
                  Know what things do before messing things up ppl. :)
                  • Predzy743
                    • 644
                    #129
                    Kamotors.. How difficult is the install?
                    88 Zinno M3
                    • AnimalE30
                      • Aug 2009
                      • 266
                      #130
                      I've just seen a few people comment on the stock injectors running on the lean side/working as hard as they can at WOT.
                      Isn't it bad for the injectors to be maxed out at wide open throttle? The point of upgrading the injectors would be making the car as healthy as I can.
                      Also - what's it take to wire the Maf into the car? Just find a 12v source?
                      • E30Nova
                        • 1546
                        #131
                        It's just internet hearsay.
                        Do you think BMW would really release a car that had insufficiently sized fuel injectors?
                        Trust me, I bought the "best" chip and 19lb injectors and noticed absolutely no gains in power/torque. I just gained a higher rev limit.
                        If you really want to make the car "healthy", get the MAF conversion kit.
                        IIRC, all you need is a 12v source and splicing a wire at the DME.
                        Matt
                        Matt
                        I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
                        Originally posted by kronus
                        try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
                        This is like a reverse build thread; it starts out nice and gets shitty.
                        • digger
                          • Nov 2005
                          • 6213
                          #132
                          Those are the people that need to start maintaining their injectors and probably the rest of the fuel system aswell.
                          • AnimalE30
                            • Aug 2009
                            • 266
                            #133
                            Oh okay, that makes sense. I'll just rebuild the stock injectors and look into the miller Maf - stock injectors should be paired with the maf correct?
                            Thanks for all the help guys.
                            • kamotors
                              • Nov 2007
                              • 7102
                              #134
                              30 minutes. just need to solder a 12v the use some hose clamps to attach the MAF, plug it in and drive away.
                              7speedshop.com
                              • u3b3rg33k
                                • Jan 2010
                                • 2452
                                #135
                                Is yours the latest revision? I was hoping that it would be 100% plug and pray (err, play). ie, no soldering.
